Spacing of Roof Exhaust Penetrations
What should the horizontal clearance be between a B-vent exhaust and a bath fan exhaust at the roof penetrations? I’m looking for the specific code reference. I am aware of the 3’ above rule. I am referencing a situation in which the B-vent is adjacent to the bath exhaust and not 3’ above it. Given the potential for interior negative pressure to draw air in through the bath exhaust, I figured it would be easy to find the code reference. No luck so far.
I can’t help you with a HVAC code reference. However, how does that kind of back drafting even happen?? For one, that bath fan has a baffle in it. More significant, because of stack effect, the main worry about that bath fan duct is air leakage from the building envelope to the exterior, not air infiltration into the building envelope. Unless the home has other air quality and ventilation issues, totally a non-issue.
During your inspection, did you see anything that brings up this concern?
The typical bath fan duct baffle (Panasonic WhisperGreen) is not self-sealing, so a negative pressure in the house can lead to air being pulled in through the bath fan. The bath exhaust head has a backdraft damper, but it also does not create a tight seal. As a general contractor, I have tested for backdrafting by running the house dryer and range hood and then smoke pen at the bath fan to see how the air moves. Sure enough, some draft is pulled in. Probably not enough to raise red flags, but we are talking about the possibility of combustion exhaust being pulled into the house.
Pictures would help.
What Code references have you found so far?
What separation is there between the two exhaust/termination vent points you are seeing?
What potential for “interior negative pressure” do you feel exists? How do you believe that “interior negative pressure” would be created to cause a draw down the bathroom vent?
You’ll have the same issue with a multi-flue masonry chimney serving a furnace/water heater terminating adjacent to a flue for a wood burning, open fireplace.
During your smoke pen test, was the air entering through the fan duct or was it bypassing the fan body entering from the attic?
Yes, with excessive negative pressure that can be obtained by excessive ventilation in modern, tight homes, issues like this can and do happen. Mostly it’s excessive depressurization that exceeds the depressurization limits of a wood or gas burning fireplace/stove, or some other combustion appliance like a water heater or furnace. That’s where the significant CO issue originates. Unless you can find a HVAC code citation, as a BPI trained building analyst, I’d not worry about the roof vent proximity issue. The flue gas is highly diluted by the outside air.
By self-sealing, do you mean it does not provide an air tight seal? The WhisperGreen models do have a damper (see pic below), as I believe almost all bath fans do. Between the damper built into the fan, the damper at the termination point (in almost all cases), and the fact that the B-vent exhaust wants to go up, not sideways, I would say horizontal clearance is not an issue. I wasn’t able to find a code reference for it either.
But, when in doubt, you can always say “I recommend 3’ clearance to building openings.” 3’ is kind of a standard clearance for natural draft appliance venting (when no other clearance is specified), but again, likely not required in this case. Also, the tiny bit of exhaust that would get pulled into the bath vent under worst case scenarios would also be diluted with fresh air.
The code references are specific to intake air, so it’s a matter of how the bath exhaust vent is classified. As it is considered an exhaust-only device, adjacency to combustion exhaust reverts to common sense. There are plenty of online opinions suggesting that there should be separation, but no studies or code language specific to sating my curiosity. In my opinion, under the right conditions (sufficient negative pressure, stagnant exterior air movement, minimal space between combustion vent and bath vent terminations, etc) a measure of combustion air could enter the fan duct and, subsequently, the house. However, without hard evidence, I can only embrace curiosity.
Yes, the baffle does not create an airtight seal. I was reviewing pictures from another inspector (since I’m also an GC) and came across a situation in which the b-vent was downhill and within 2’ of the bath exhaust t-top. Again, I am more curious about code-compliance rather than having a specific issue that needs resolution.
Thinking of what I’ve seen as a retired GC and active HI; I’ve seen a lot of HRV exhaust termination hoods located 12 inches m/l from a power vent termination from a water heater or furnace. The code illustration that I work from addresses combustion appliance vent termination proximity to air intake locations. I never have been concerned about the proximity of two exhaust terminations.
You should ask one of your HVAC contractors, since you’re an active GC. Report back on what you learn!
As an edit, CO becomes an issue when it’s 30ppm or so in the home. Many homes with combustion appliances, especially a gas range, test at 1ppm up to 3ppm from my work. I don’t think your condition will become a source for high CO inside the home. Of course, my opinion…
I gave it the old college try looking for a code reference. There are plenty about clearances to everything, except exhaust vents, lol. That said, someone may come along with a code reference.
The local AHJ did not know a code reference when you asked them?
Haven’t asked them yet. I was hoping a bit of due diligence and CPI interaction would shed light. Alas, I am once again stumbling forth with more questions than answers….:wink:
There is no IRC reference for this situation as an issue is not expected to happen from that condition. Of course the Building Codes (we expect the IRC is being referred to here) are not complete in many different aspects.
I just asked Grok your question and this was the response I got:
No, there are no specific code references in the International Residential Code (IRC) or International Fuel Gas Code (IFGC) that require a minimum clearance distance between a bathroom exhaust fan termination and a gas-fired appliance exhaust vent termination.
Bathroom exhaust air (from toilets, baths, and kitchens) is explicitly not considered hazardous or noxious under the IRC (e.g., referenced in discussions around R303 and M1506 sections). As a result:
Bathroom exhaust terminations follow general rules in IRC Chapter 15 (e.g., Section M1506 or equivalent in various editions):
At least 3 feet from property lines.
At least 3 feet from operable or non-operable openings into the building (windows, doors).
At least 10 feet from mechanical fresh air intakes (or 3 feet above the intake).
Terminate outdoors with a backdraft damper.
Gas appliance vents (e.g., furnace, water heater) have strict termination clearances under the IFGC (Chapter 5) or manufacturer instructions to prevent flue gases from re-entering the building via intakes, windows, or doors. These focus on protecting intakes and openings from the appliance exhaust, not from non-hazardous exhausts like bathroom fans.
The concern is typically one-way: preventing dangerous combustion gases from being drawn back into the home. Bathroom moisture/odor exhaust poses no similar risk to the gas appliance vent. Sources like InspectAPedia and code forums note that as long as the bathroom termination follows its own rules, no additional separation from gas vents is required.
Best practice suggests reasonable separation (e.g., a few feet) to avoid aesthetic issues or minor recirculation, but it’s not code-mandated. Always check local amendments or manufacturer instructions, as jurisdictions may vary. For the latest (2021+ IRC), confirm via ICC digital codes.
You are going down a rabbit hole with this and may well meet Alice along the way. You’re working to hard to find something that does not exist.
Nothing wrong with thinking, having an opinion, and working through an issue. However if you are unable to measure dangerous levels of flue gasses coming back down the bathroom vent there is nothing to report. We can continue to hypothesize of what may happen under many other situations we see during inspections. It does provide value to help us learn more but when an Inspector gets hung up on hypothesizing at every turn they will drift far away from their intended function.
I also clicked the “think harder” button and got this response:
there are building code references for the termination locations of both bathroom exhaust fans (classified as environmental air exhaust) and gas-fired appliance exhaust vents, but no standard codes like the International Mechanical Code (IMC) or International Residential Code (IRC) mandate a specific minimum clearance between these two types of terminations. Each type has independent requirements for distances to building features like operable openings, property lines, and air intakes to prevent nuisances, contamination, or hazards. Local jurisdictions may have amendments, and manufacturer instructions for the gas appliance often take precedence, sometimes specifying clearances to other vents (e.g., dryer or water heater vents, but rarely bathroom exhausts explicitly).
Considerations for Proximity Between the Two Terminations
No Explicit Code Requirement: Sources like InspectAPedia and building forums confirm that standard codes do not specify a minimum distance between environmental exhaust (bathroom fan) and appliance exhaust (gas vent) terminations, as neither is considered an “intake” relative to the other.c63ec597115acb1180 This is because the primary concern in codes is preventing exhaust from re-entering the building via intakes or openings, not interactions between two outlets.
Potential Practical Issues: Close proximity (e.g., less than 3-5 feet) could lead to re-entrainment of flue gases into the building under certain wind conditions or if the bathroom fan creates negative pressure, potentially causing odors or safety risks like CO backdrafting.6cf008 Some installers recommend at least 10-12 feet separation for caution, similar to clearances for dryer vents or other moisture exhausts mentioned in some furnace manuals.3857f1
Manufacturer and Local Guidance: Always check the gas appliance’s installation manual for any additive requirements (e.g., clearances to “other appliance exhausts” like dryers, which might analogously apply).39f134 Contact your local building department for jurisdiction-specific rules, as states like California or Washington may have amendments (e.g., via energy codes or local IMC/IRC adoptions).
The house would have to be in a negative pressure for what you are asking to occur. Then the exhaust coming out of the b-vent would have to defy physics and fall instead of rise. The CO then navigates its way through a 4” warm air pipe and a closed damper that has a free area of next to zero.
For reference, on a 50-gallon water heater, there should be around 35 PPM of CO at the storm cap.
How many PPM of CO are you expecting to find in the bathroom in your scenario?
My initial post made it clear that I was starting from the premise of a significant negative pressure scenario. I thought it constructive to discuss with other CPI’s to flush out the idea and see if there were others who shared a curious building science spirit. The house in question has a water heater vent roughly 2’ from the bath exhaust t-top and the b-vent is downhill.
As for PPM at the fan, I would assume it to be relatively minimal (if at all). However, without finding published studies, one could say there may be 0 ppm or 5 or 10 or…. Again, I find these threads to be helpful to flush out concepts.
Would I as a GC place a combustion exhaust vent anywhere near another exhaust vent that may even have the possibility of intake? Absolutely not. Better safe than getting a call from a client who runs the gauntlet of exhaust (powerful kitchen hood and dryer running, fire roaring in the fireplace, etc.) who has a hyper-sensitive nose when she goes into the bathroom to check her reflection.
What do you put in your reports about homes with gas ranges?
Sigh. When a client stands next to her gas range to cook her morning eggs, there’s a reasonable expectation that she will identify quite clearly the smells associated with the effort. When she steps into her bathroom, I doubt she expects a whiff of her cooking fuel coming from the ceiling. Again, and I write it again, the purpose of my initial post was to see if any of the experienced CPI’s have come across a code reference, or scenario, in which combustion gasses were drawn into an exhaust vent. I have, as a GC, experienced the intake of air from an exhaust vent, but it did not involve a combustion-adjacent component at the exhaust. Hence my curiosity.
