Sparse 1x roofing decking on old house
Did an inspection on a 1,702 sq ft, 1917, 3/2 today. It had a metal roof. The roof structure was very minimal. I’ve seen 1x spaced plank sheathing before, but never like this. Has anyone else seen anything like this? I feel it’s ok, for the weight of a metal roof, but part of me feels like there should be more.
Skip sheathing was very common (and might still be in some locales), but around here they require full sheathing before a roof can be replaced or upgraded.
Hey @ddagostino Thanks for the clarification. I was unaware of “skip sheathing”. A quick search revealed what I needed to know. Thanks again for the knowledge!
It looks like plenty of support for the metal roof. But it does make installing a proper underlayment basically impossible. Lack of an underlayment would be noted in my report, along with a picture explaining why.
@ruecker good point. Thanks for the insight.
Exactly. Should have underlayment beneath it. See this from time to time around here…but with underlayment. :slight_smile:
See this on 100 year old homes all the time. Perfectly normal for that period.
Skip plank sheathing.
While it is technically possible to install a metal roof without a solid wood sheathing layer (known as “open framing”), it is generally not recommended for residential homes and may not be acceptable depending on local building codes.
Here is a breakdown of the considerations:
  • Building Codes: For most residential applications, sheathing (plywood or OSB) is typically required by local building codes for structural support (diaphragm shear) and to meet requirements for multiple moisture barriers.
  • Condensation and Moisture: A significant concern with open framing is condensation. Without sheathing and an underlayment/vapor barrier, moisture can accumulate on the underside of the metal panels, potentially leading to issues like mold, rot, and rust over time.
  • Ventilation: Proper airflow is crucial. If sheathing is omitted, horizontal purlins (wood strapping) are often installed across the rafters to create an air space, which helps with ventilation and prevents moisture buildup.
  • Performance Issues:
    • Noise: Metal roofs without sheathing lack the sound-dampening layer, making them significantly noisier during rain or hail events.
    • Insulation: Sheathing improves the roof’s thermal performance, acting as a better barrier against heat and cold.
    • Warranty: Some manufacturers may not warranty their products if the installation instructions (which often require a solid deck) are not followed.
In summary, for a standard residential property like the attic space shown, a metal roof without wood sheathing is often not an acceptable or advisable solution due to potential structural, moisture, and performance issues, as well as likely non-compliance with building codes.
The roof deck framing is referred to as Skip Sheathing.
I was called as a witness of fact or custodian of record.
A barrier is required. Installing a metal roof over skip sheathing, spaced boards, creates a unique assembly that requires careful moisture management to prevent condensation from damaging the roof structure. The primary rule is to manage condensation ***on the underside of the metal, and to ensure the assembly is properly vented.
What I am seeing in the images are symptoms of a general lack of purlins (strongbacks) and bracing with all of the ad-hoc additional bracing and repairs. I am seeing sistering of rafters and some skip-sheathing that was replaced in one section for some reason; could have been a tree limb, but who knows. IMHO, this roof is barely strong enough to handle the static loads of the metal roof, let alone any high wind loads, potential snow loads, and possible additional sheathing added in the future. But, I am not a roofer… If it were me, I would recommend that the roof be evaluated by a roofing specialist.
I see the 2x is extremely bent under load and one has split in half as well. Regardless of things others have mentioned, that seems to indicate the support structures in place aren’t acting as intended.
I see bowed supports, sagged rafters that have pulled nails and broken members and sistered two piece rafters and all with minimal supporting structure.
I would recommend a qualified framing contractor that uses the services of a structural engineer to assess and make repairs or replacement as needed to maintain the structural integrity of the roof structure.
Like agents love to say, “all real estate is local.” So are inspections… metal roofs with no underlayment over skip sheathing and sparse framing are an everyday thing in Hawaii. There’s also no snow load and virtually no condensation.
Typical framing for 1900s cedar shingle framing. Framing typically weak by today’s standards and often sagging. Otherwise condensation would be a concern for me.
