Anyone have a template for big multi apartment complex. I still struggle with formatting these jobs. This one is 36 units plus the common area areas. I’ve made a template before, but it was a bit clunky and I didn’t love it.
Just use your standard template, while inspecting copy sections and rename them for the unit. No need to over think it.
It’s much faster to do it in the field then on the computer.
Wondering if giving common areas their own section and then duplicating a unit template beats one giant template. Multi-unit layouts always look fiddly.
Depends on how you are to populate the defects. Are you going to have a separate photo and defect narrative for every individual defect for each unit? That is a lot of photos of loose receptacles and missing drain plugs. Are you using the CCPIA SoP or ASTM?
