That’s weird how the exhaust pipes are side-by-side in the utility room, but at the exterior wall we are seeing one pipe directly above the other pipe.
Was there a fresh air intake for the utility room going out the exterior wall? All I see is an intake that’s pulling air from the utility room.
It looks like the fresh air intake and the exhaust pipe were installed improperly, according to the manufacturer’s installation instructions.
So they had a 2.5 inch concrete hole saw in the van. They had a 3.5 inch OD PVC pipe. Need a clean hole in a slab side. Solution? Use a WYE, make two holes. A 3 inch PVC pipe is roughly double the air volume of a 2 inch PVC pipe or equal to two 2” pipes.
The one pipe was originally going to be the intake, based on the labeling. My WAG is that they found out the exhaust was too long for a 2” pipe, and instead of replacing with 3”, they combined the intake and exhaust to replicate a bigger exhaust.
It’s not conventional, but I wouldn’t say improper necessarily. It should exhaust fine.
One thing I would be checking is if the utility room is big enough to provide adequate combustion air. Any other gas appliances in the room? Clothes dryer in the room? Any outdoor combustion air provided to the room? etc….
