I have a home that requires testing for offspray insulation offgassing. The home smells sweet, fishy and a little chemical. The whole home is full of sprayfoam insulation all over the walls and ceiling. Is there a lab or place that can test the offgassing of the sprayfoam insulation to see if it was mixed improperly or was curated wrong. Is there a lab that I could send a piece of the sprayfoam insulation for them to test? I have called AIQ and hygenistic and even reached out to specilalist and they dont perform this type of testing which is Isocyanates (A-Side / MDI) and Amine Catalysts & Polyols (B-Side). is this something that can be tested especially hear my home are which is el paso tx, as most companies that offer this service are in the main cities such as houston which is 8 hours from me.
Begin with the MSDS… (Material Safety Data Sheets (MSDS), now officially called Safety Data Sheets (SDS), are standardized documents providing vital information on chemical properties, health hazards, protective equipment, and emergency response procedures. They follow a uniform 16-section format to ensure safe handling and compliance).
Whoever installed the sprayfoam should have presented a copy for the Homeowners use and record. If you don’t have one, get it!
Once you have the MSDS/SDS, use the information here to guide you to the manufacturer for assistance…
If unable to get a copy of the MSDS/SDS, contact EMSL for information on submitting a Sample for testing.
thank you for the information and will sure do, however i contacted EMSL and they stated they could not help when testing offgassing of sprayfoam insulation… maybe im saying the wrong thing but i have emailed them as well no support so far
My understanding, (from years of general education, non-specific to off-gassing), is that ‘Off-Gassing’ testing is not possible (or practical) for “Small Sample” Laboratories to perform, thus my suggestion of determining the Manufacturer of the product, and contacting them for assistance.
IMO, your best chance of proceeding is to contact (one or more) an “Industrial Hygienist” for further advice/guidance. That being said, they will most likely require a site-visit with extensive testing to narrow down your concerns. Prior to the visit, be certain to inquire what prep you should or should NOT perform in advance of the visit.
Throw it back at the Builder! You have legal rights you need to take advantage of.
If the Builder doesn’t step up and get involved, contact your Attorney immediately, as yes, there are time-frames at play, if it’s not already too late!!
its been almost a year and the smell is stil there and its not a new house smell, im vey minimalistic therefore its not offgassing of new furniture either as i have not bought anything new for this home
