I mention it because if you do not then you will get sued. Fuses same thing just add recommend to update, recommendations are not a problem more of a heads up.
Most people understand that.
*FUSE PANELS ARE GENERALLY SEEN AS BEING MORE RELIABLE THAN BREAKER PANELS DUE TO THE FACT THAT THEY WILL ALWAYS TRIP WHEN OVERLOADED BY EITHER LOADS IMPOSED ON THEM OR UNDER DEAD SHORT CONDITIONS. BREAKERS ON THE OTHER HAND HAVE BEEN KNOWN NOT TO TRIP AT THE SPECIFIED AMPERAGES.
MANY INSURANCE COMPANIES HOWEVER WILL EITHER NOT INSURE, OR INSURE AT A HIGHER PREMIUM HOMES THAT STILL HAVE FUSE PANELS. THIS IS NOT DUE TO ANY DANGER FROM THE FUSES THEMSELVES, RATHER IT IS INDICATIVE OF A GENERALLY OLDER UNIMPROVED SYSTEM WHICH STATISTICALLY WILL PRODUCE MORE ELECTRICAL FIRES.
That is my stored Library phrase.
Sorry author unknown.
I think I need to convert to small case lettering.
