Strange light switch operation
I had a light switch that CONSISTENTLY worked every other time. I tried it about 20 times and every other time the light would come on. I could wiggle the switch and it would not flicker, like an intermittent switch.
It even worked as described when demonstated to the realtor (that’s the real test - when you tell someone and it actually does what you describe :slight_smile: )
Any ideas?
I had a remote (radio transmitter type switch) that functioned like that.
You had to wait between operations of the switch.
Must admit I would have removed the plate to look.
Visual is nice as a theory but…
I had a helper that worked like that.
