Is anyone identifying the type of stucco in their inspections? If so, how….when we only see the finish coat.
Tap on it.
Solid sound = hardcoat stucco system.
Hollow sound = EIFS stucco system.
…among other ways.
Nice! Thanks for simplifying this
Evening, David. Pleasure to meet you.
You ask a good question.
One learns to Identify stucco visually, through sound and instrumentation, IR. The more you practice observing stucco on site the more you will become familiar with the types of stucco in the field.
InterNACHI provides comprehensive guidelines for identifying stucco types.
Traditional hard-coat vs. EIFS - Exterior Insulation Finishing Systems. Usually/typically by testing for rigidity of the assembly. Hard-coat stucco is firm, rigid. EIFS - Exterior Insulation Finishing System gives a little when pressed somewhat feeling soft, thus tapping for sound, tapping with a rigid hard plastic sounds hollow vs. solid high pitched when tapping.
Checking for foam insulation beneath the surface is possibly a giveaway. Look at the bottom of the assembly like looking at siding.
Key inspection areas include looking for weep screeds/drainage at the base, damage revealing foam, and assessing flashings.
Resources like InterNACHI’s Stucco/EIFS Inspection Course and Stucco Identification Decision Tree Card designed to aid identification.
Read articles by Ron Huffman.
Registered Professional Engineer in Colorado
Registered Professional Engineer in Wyoming
Certified Member of the International Association of Certified Home Inspectors
Certified Third Party EIFS Inspector by EDI.
Certified Moisture Analyst by EDI
Trained in EIFS Remediation by the NAHB Research Center
Certified by NEHA’s National Radon Proficiency Program
Certified EIFS Professional by Association of the Wall and Ceiling Industries
Try this: New Online Video Stucco/EIFS Course Designed Specifically for Home Inspectors! - InterNACHI®
Good luck.
Tell us how its going out in the field.
Best regards.
Robert Young (CPI) (CMI)
Thanks so much - great feedback
Yeah, differentiating EIFS v. Hard Coat is pretty important. Good info so far. For me, it’s all about the sound/feel. One quirk is that you will often find a hard cement system but the tapered/tiered details around pillars and windows will be EIFS. Cement is heavy and hard to get into pretty shapes and tiers. Foam EIFS is light and easy to make pretty shapes out of.
For reporting, this is one of my rants about our industry… If you know something, feel free to differentiate but when you’re .0001% unsure, list it as “Stucco/EIFs” in your report. No one is EVER going to notice or care but down the road if you’re wrong it’s FAR easier to defend yourself if you didn’t promise someone one product and you are wrong.
There are all kinds of examples of this in modern software that put us at risk. I don’t ID a garage fire door as “solid wood”. I just say “wood”. How do I know there isn’t a hollow core or some foam? Kitchen cabinets. I never say “wood”, I say “wood/wood composite”. Countertops aren’t granite, or quartz or marble. They are “stone”. Garage doors aren’t steel or aluminum, they’re “metal”. Inspectors are a VERY insecure bunch and are always looking at ways to look and feel smart. Don’t be one of them. I’ve been at this 26 years and counting and am pretty damn sure I know what I’m looking at all the time but I am wrong at times. There’s no upside in taking on liability you don’t have to. There’s nothing worse than trying to defend promising a client one product when they have another. Best thing is what you’re doing… learning differences but always take shelter from unnecessary liability when you can.
Great insight and appreciate the notes on report verbiage
In short, nope and I strongly advise you against identifying the stucco system, unless you are excellent with stucco.
About ten or so years ago, I counted seventeen variations of what we call “stucco.” How good are you with all of those. I am pretty good, and I struggle to identify all of them, particularly since I rarely to never see twelve of them. There are some new variants since then, particularly the proprietary versions.
A house might have more than one system. I inspected a house with three different types of stucco. 98% of the time, the identity of the stucco system doesn’t matter to our client. But when it does, you better be correct.
If you have the misfortune of having a client that insists on identifying the stucco system, tread carefully. As an example, if you are sure it is MD-EIFS, report “The stucco system appears to be MD-EIFS. I recommend evaluation by a stucco expert.”
Years ago, an inspector here got sued by the seller of a home for mis-identifying the stucco system, and lost. The inspector reached under the edge of the stucco. It was about 1 1/2" wide. He reported EIFS. The buyer knew about the issues with EIFS and walked. It took the seller another few months to sell the house in a depreciating market. But, the house did not have an EIFS system. It was a hybrid hard coat with a foam backing. The inspector’s misidentification cost the seller about $50K with holding costs and lower sales price.
It is definitely good for you to know the stucco system you are inspecting. But, keep it to yourself. Report the defects, if any and keep the system ID to a generic, “stucco.”
