Student discussion on Decks
Maybe I’m getting ahead of myself , but in the beginning of the course on decks, it states that only sawn wood decks will be discussed, and not any other materials like composite. Why is that?
Composite decking still has a wood structure.
You need to learn the basic construction and defects of wood before tackling some of the more expensive and unique decks like steel and suspended concrete slabs. Unless you’re doing commercial work, wood decks on residential structures is 95% of the decks you will see.
You are correct, I do need to learn more, however I at least would like to know if the information I seek can be attained from InterNACHI, possibly in an advanced course or is it just not pertinent to our scope?
What exactly are you hoping to accomplish or the detailed deck information you think you need to be proficient.
Well, I was kind of expecting to get the same information as was described in the siding and roofing materials; material make up, moisture resistance, durability, strength, if psi rating is same as wood for composite. I figured if I’m going to encounter something during an inspection I don’t want to seem uneducated. I’ll reach out to the manufacturer for further information.
Some of the composite deck material requires closer spacing of the deck floor joist and stair stringer spacing. I have seen thermal expansion issues causing buckling to occur.
For engineered specs, its best to look at the manufacturer specs for detailed installation guides. Sometimes they have little to no information, however, sometimes they have great illustrations. You can find most off have the big box stores websites for what they’re selling.
Thank you for your response
99% of the deck “structures” that I inspect are constructed with wood. Usually, composite is only used as a “decking material” and not for the other major structural components of a deck, at least from what I’ve seen over the last 23 years.
Here is another document that you may find useful, I use it as my “deck bible” and is my go-to guide whenever I have questions about a component or construction methods used to build a deck. It also comes in handy whenever I’m being questioned about a deck that I’ve written up.
Of course this MB is a great resource as well. :+1:
DCA6 Prescriptive Residential Wood Deck Construction Guide Based on 2012 IRC
