Student Discussion: Pre-Drywall Inspection Course
Task 1: Decay Protection Inspection Response.
One of the critical responsibilities of a home inspector is inspecting for decay protection. In the IRC, section R304 outlines requirements for safeguarding structural wood against fungal rot and moisture intrusion. Specifically, it mandates proper ground clearances, field treatment of cut ends, lumber quality marks, and corrosion-resistant fastener types.
Ignoring these standards during an inspection can lead to severe, hidden damage. When defects like missing capillary breaks or improper soil contact are left unnoticed and uncorrected, load-bearing framing can become structurally compromised. Not only can the framing become compromised, but organic growth can present, and the resulting repairs can prove extraordinarily costly.
IRC
Writing Assignment - Inspecting allowable spans and materials at home.
If spans and the potential loads placed on those spans are not questioned by a city inspector or if they do hire a home inspector that can at least question the builder on the load and span it could save people a lot of money down the road in lawsuits.
I built 3 spec homes and on my second one some changes were made on the fly and a loft was added above a living room from a secondary staircase that was added along with the loft. It was all framed and the intent was to place a Baby Grand piano up on the loft once finished to show buyers what this loft could be used for. No engineering no plans initially were even drawn. But the city inspection gent caught it and demanded engineering. Well luckily the home planner (not an architect) knew his construction and drew the plans and got them stamped and engineered and our house was then able to be continued on with construction. But the sure load along with the long span was the potential deal ender on that house.
Task 1: Inspection of Allowable Spans and Materials
Another critical responsibility of a home inspector who is completing a pre-drywall inspection is to verify materials and their allowable spans. Joists, rafters, and beams must adhere to strict guidelines provided in span tables within the IRC. These tables specify material type, spacing, and recommended span. An inspector should verify these standards before each item is sealed up.
Inspections are necessary. Omitting them may lead to missed structural defects that could pose long-term issues further down the road. It can cause cracked flooring materials and drywall, floors to sag, and in extreme cases…structural damage. Thorough home inspections protect the occupants and the longevity of the house.
Task 1, Decay Protection Inspection: Proper decay protection is essential to maintaining a home’s structural integrity. During an inspection, wood framing, sheathing, siding and other vulnerable materials should be checked for moisture exposure and adequate protection. Neglecting these areas can allow water intrusion, wood rot, fungal growth and deterioration, potentially leading to expensive repairs and structural damage, not limited to termite infestation. Thorough inspections help identify deficiencies early and protect the home from long-term decay.
Task 1, Inspection of Allowable Spans & Materials: Without proper inspections, a home could be constructed with structural members that exceed allowable spans or with materials that do not meet building-code requirements. This can result in sagging floors, excessive deflection, cracking, or other structural problems. in severe cases, inadequate materials or improper spans could contribute to partial structural failure. Proper inspections help identify these issues before they become costly or dangerous.
The consequences of a client skipping an inspection of the allowable spans and materials could be detrimental. Flooring could end up uneven at best and flooring could become dangerous at worst, becoming unable to handle loads. Use of improper materials could lead to wood rot and/or pest intrusion. The consequences of performing an inadequate inspection of these spans and materials could land an inspector in a lot of hot water later should these conditions be insufficient.
Decay protection, inspection essay.
Some people like to build their own stair deck out of mobile home exit areas. Either the support system is on cement or on the ground adjacent to the opening of the home. Without the protection of treated wood or moisture barriers, the wood or metal can rot, mold, rust or corrode, causing the structure to be weakened overtime. This compromises the stability of the structure whereas, the stairs can weaken, sag or collapse, making it a safety issue. The proper zinc coated fasteners and moisture barriers between the different types of materials will help prevent safety and longevity of their stairways.
Decay protection is vital for homes of all types, especially in new construction that must adhere to current building codes and standards. Proper inspection and identification of building materials used in areas such as floor joists, rim boards, support beams, even siding and exterior sheathing are can be prone to decay and rot that can spread once it has set in. Proper use of appropriate corrosion resistant fasteners and nails such as stainless steel, hot-dipped galvanized steel, silicon bronze, or copper is important as the chemicals within fire-retardant and preservative-treated wood can accelerate corrosion, which can lead to weakened structural integrity of a home.
Having been licensed in Texas since 1989 every time I read all of the interesting info I realize how much I have forgotten in over 30 years. I try to have WDI inspections on existing homes and I have leaned some from that. It is good to learn by myself and Internachie. Most of what I have read so far is going to be very helpful to me, my clients and MY business. Most of it is a refresher of my working life. Good to see it in writing where I can chew on it for awhile.
Task-1 Decay Protection Inspection
Living and working in Georgia makes decay and termite protection especially important because of our heat, humidity, rain, dense vegetation and moisture. Those conditions can make homes more vulnerable to wood decay and termite activity if the proper termite protection is not installed during construction. I have seen how serious this can become firsthand. In my childhood home, the builder failed to remove some of the wood forms around the concrete slab. Those pieces of wood were left in contact with the structure and essentially created a highway for termites to travel into the house. It became a good example of how one construction mistake can create a major problem years later. When inspecting a newly built home, it is important to look carefully at areas where wood is exposed to moisture or close to the ground and to make sure proper flashing, drainage, treated lumber, and compatible fasteners are being used. In Georgia, these inspections are especially important because decay and termite problems can develop quickly. Catching these issues early can help prevent structural damage and very expensive repairs later.
Inspecting for allowable spans and materials in new construction is crucial to ensure the longevity of the building. Two sheets of material may appear almost identical but actually be rated for different applications and mixed together on the job sight. what appears to be 2x12 rafters way over head may actually be only 2x10s that are over spand. ETC.
During a predrywall inspection if components that prevent decay are lacking or not correctly installed, it could create costly problems for future owners of the home. Defects that allow water penetration that are behind wall coverings are difficult to repair once the home is built and are expensive to repair. Additionally, using the incorrect fasteners in treated wood are a structural hazard.
Structural members that are not properly sized based on their span and material type will experience deflection. This will cause damage of finished surfaces and an unhappy home owner.
Task 1 decay protection
Decay protection is especially important here in the Pacific Northwest, where extended periods of rain and wet conditions expose a home to moisture for much of the year. If a newly constructed home is not properly inspected, missing flashing, inadequate clearances, or improperly protected wood can allow moisture intrusion to go unnoticed. Over time, this can and most likely will lead to wood decay and structural damage. Finding these issues during construction, before they are concealed, can prevent expensive repairs and help ensure the home is prepared for our wet Northwest climate.
Inspecting the materials used and the allowable spans of ceiling and floor joists and rafters is an important step for inspecting a home, especially during a pre-drywall inspection where it is the last time anyone may see the framing of the home. Proper use of certain species of woods, such as Douglas fir-lartch, southern pine, hem-fir, and spruce pine-fir, along with spans based upon specific dead loads and connection method used are key aspects when it comes to designing and building a structurally stable home. Over sized spans or use of inappropriate wood species can compromise a homes structural integrity, which can lead to major damage to a home that can be very costly to fix.
Inspecting for decay prevention
During a pre drywall inspection there is high importance in inspecting the wood components. This is especially important in a high termite infestation area like Florida. Decay prevention measures must be taken like termite shields (physical barriers), bait stations or pressure preservative treated wood. If a home is built without these strategies in place, termites can intrude into the wooden components over time and cause thousands of dollars of damage. Much of this damage goes unnoticed for years because it is covered with siding and drywall. By the time the damage to the outer layers is noticed (cracking, sagging or moisture), the framing is beyond repair. While all of the structural components are visible pre drywall, that is the time to ensure proper clearances, treatments and markings.
just passed my state cerrtification and excited to add pre dry wall to what i can offer my potential clients
This essay is for the section of inspecting for allowable spans. In a new construction home, when a beam or joist is supported at each end, there is a maximum span for the species of the wood and size of the beam. When supported at each end, the compression load is at the top of the piece and the tension is at the bottom. If the span exceeds the requirements for the species and load, the supporting member will sag over time. This can cause many different issues. Such as, floors being uneven, doors not closing properly, cracked drywall, etc. A worse case scenario is that the member actually crack or break causing catastrophic damage and costly repairs. Having the correct species and size from the beginning will prevent these disasters and create longevity in the structure.
Decay Protection Inspection writing assignment:
Use of proper fasteners in pressure-treated lumber is critically important due to the corrosive nature of the treatments used to preserve the lumber. All holes, cuts, and notches must be field-treated to restore the protection of the lumber. All fasteners and hardware should be hot-dipped zinc-coated galvanized, copper, silicone bronze, or stainless steel. Plain carbon steel nails and fasteners will corrode and potentially lead to structural failure. Personal construction remodeling experience in removing a roman tub, found carbon steel nails were used with pressure-treated lumber and most of the 16d nails were the size of 6d or smaller nails. It would have been a short time before there were no effective fasteners remaining.
In most jurisdictions in our area, residential building plans need a structural engineer stamped set of plans for permit review and issuance. As a pre-drywall inspector, I should review the plans and verify that all beams, joists, rafters, and sheathing meets the requirements set by the SEOR, understanding that I have no inforcement authority. Being familiar with code allows me to verify the members meet the allowable spans and if they are not properly installed for size and rating, must be identified and reported as such. This hopefully will help keep my client from experiencing catastrophic conditions later on.
