Student Discussion: Residential Plumbing Overview for Inspectors Course
The issue for inspectors is that you can’t see the high loop while the dishwasher is installed.
My question relates to Expansion tank or Expansion valve requirements for homes with Pressure Reducing Valve and Tankless water heater. Is the Expansion tank/valve required in this instance?
Texas TREC SOP requires measurement and reporting of the static water pressure.
I’m starting my plumbing course and am trying to use the discussion forum. Having some difficulty, am I doing this right?
Doing great, @jhenderson34.
after the meter
Just started the residential plumbing course.
I am about to begin. Looking to do the same thing 2 days to complete plumbing
I didn’t know that, glad I am starting the course and further learn more about plumbing inspections.
beginning the plumbing course. looking forward to adding to my repertoire. :smile:
Starting Plumbing!
I’m right there with ya bossman
Same here, starting plumbing for state CE’s
I’m looking forward to learning about how to inspect residential plumbing.
I’m with you on this one. Learning more about residential Plumbing is interesting to me as well.
Residential plumbing course is in progress.
Starting the course!! Google, here I come…
Going through the course I realized that I have seen homes with water heaters without expansion tanks. They might have been older homes. Does anyone know when (or if) the requirements changed?
Notices a build-up on the exhaust from a hot water tank. What would be causing this buildup and is this a safety concern that should be reported as a defect?
Jumping into this one, looking forward to it.
