Question: What is the definition of light-framed construction?
Answer:
Based on the definitions provided in the IRC, light-framed construction basically describes a structural method where the entire skeleton of the building is put together using a repetitive grid of smaller members rather than heavy post-and-beam or masonry work. It relies on closely spaced components like studs, joists, and rafters, which are primarily made out of either dimensional wood or cold-formed steel to carry the structural load of the home.
Question: Where natural light is used to satisfy the minimum illumination requirements, how is the minimum required amount of glazing determined? Where artificial light is used, what illumination level is mandated?
Answer:
According to the rules laid out in Section R303.1 of the IRC, when you rely on natural daylight to light up a habitable room, the code states that the total window or glass area must measure at least 8 percent of that room’s total floor area.
On the other hand, if you choose to utilize artificial lighting instead of windows to meet the lighting demands, the fixtures must be capable of producing an average illumination level of at least 6 footcandles. This brightness level needs to be distributed properly across the room and is measured at a specific height of 30 inches above the floor line.
This response is regarding the study session 17 writing assignment for the 2021 irc exam study course. Bonding is required to ensure electrical continuity at ferrous metal raceways for grounding electrode conductors, grounding electrode system, swimming pools, spas, hot tubs, hydro massage bath tubs, circuit conductors in raceways. Permitted methods for Bonding are grounded service connector/conductor, threaded connections, threadless couplings and connectors, other approved methods.
This response is regarding study session 18 for the 2021 Irc exam study course. Arc fault circuit interrupter protection is required at branch circuits that supply 120 volt, single phase, 15 and 20 amp outlets installed in kitchens, family rooms, dining rooms, living rooms, parlors,libraries, dens,bedrooms, sunroof, recreation rooms, closets, hallways, laundry areas.
Specific shall be required over general then there is a conflict because the specific requirements are more direct and precise. Which would leave less error for misinterpretation.
This is a building process where the roof, walls and floor are built of light weight lumber. Which would accounts for most of the housing or homes built today.
Where must illumination be located in relationship to interior stairways? Exterior stairways?
Interior stairway must have lighting at he top and bottom landing and for stairways with six are more risers should also have a light switch at the top and bottom. For exterior stair ways they should have light at the top landing.
In reference to writing assignment #1, 2021 IRC Exam Study Course: The main purpose of the IRC is to protect whoever is living in dwelling from fire and life hazards, to ensure the integrity of the dwelling meets building standards, the welfare of the occupants, and to ensure builders and contractors are to a consistent standard.
The scope of the IRC is for single-family dwellings and townhomes/duplexes dwelling no more than three stories high
In reference to writing assignment #2 - The definition of light-framed construction is walls, roof, or floors made out of wood studs / cold formed steel in a regular interval pattern.
In reference to writing assignment #3 - Where must illumination be located in relationship to interior stairways? Exterior stairways?
Illumination for the interior stairways must have the treads and landing illuminated with a 1’ candle measured at the center of the landings and treads.
Illumination for the exterior stairways requires a light source at the top of the landings and for stairways leading to a basement requires the light source at the bottom of the landings
