Why would someone install plywood in some areas and some sort of thermal reflective barrier in other areas of the sub-floor of a crawl space? There were some openings from which I could confirm the presence of fiberglass batt insulation. This is totally unorthodox in this area of the country and I don’t like it because it conceals the structure from inspection for possible defects. Other than that, is there a downside to having it installed? Would you recommend its removal?
Looks like a waste of the “Product” if in fact it works like they claim…I see it once in a while here in AZ (attics)…supposed to “Reflect Heat”…my IR Thermometer seems to beg to differ with the product data information—
I do not think lack of viewing pleasure is enough to recommend removal any more than I would suggest taking down all the drywall in a finished basement.
Joe, I don’t really see anything wrong with it, but sure there might be pros and cons in Building science in doing it that way.
It could depend on the surrounding conditions also to establish if it could be a problem or not.
I have seen it occaissionally up here. It is a vapor retarder as well as an insulator.
