If you were going to install a subgrade stairwell, where would you generally place it?
At the lowest grade elevation available of course…
Why not?…:D…](*,)
Does that qualify as an in-ground pool also?
The last time I seen one of those bulkheads below grading, I found a situation like this…
http://www.licketyknit.com/wp-content/post-photos/FloodedBasement.jpg
yep…definitely an in-ground pool.
can anyone say sink hole!:shock:
Me tinks da retain’n wall waz a good fix:roll:
The Retaining Wall (Ungrouted) was an add on (most likely as you suggest).
