bkelly2
(Brian Kelly, AZ Cert. # 60234)
April 19, 2011, 4:04am
I became aware of Foundation problems in this area a while back.
This makes an interesting read. I had never heard of this before myself.
http://www.inmaricopa.com/NEWS/NewsArticleDetails/tabid/99/Default.aspx?ArticleID=8536&&mid1=390
Study shows sulfate issues restricted to Maricopa Meadows
By Michael K. Rich
June 24, 2010
The results are in, and Maricopa Meadows stands as the only subdivision in the community with sulfate levels high enough to cause moderate damage, according to the International Building Code.
http://www.inmaricopa.com/NEWS/NewsArticleDetails.aspx?mid1=430&ArticleID=8798
bkelly2
April 19, 2011, 4:12am
2
Darren noted it last year here.
There is a class action suit in the making involving thousands of homes. Supposedly the builders did not do soil tests to detect high sulfates, and therefore did not use type v concrete. I have heard of this problem in California, but this is...
tspargo
(Tim Spargo, CMI)
April 19, 2011, 3:33pm
3
I see it in different areas… all the time. It’s not just the foundations, it’s the flat work and other hard surfaces. What’s appears to be efflorescence at first, may ultimately be just that, or, will progress to a Spalding mess in years to come, as HI’s, it’s impossible for us to predict IMO.
In the tracts, if you were to look at the soils reports and the SE’s rec’s for the mix, you’d probably not find the correct types of mixes used. Would we know that…? I’m not sure how. Ugly issue, either way you slice it up.
bkelly2
April 19, 2011, 8:51pm
4
tspargo:
I did not have any idea about Sulfates before Tim. Very interesting and eye opening.
