Supported sill plate
Today’s inspection was a 1,503 sq ft, 3/2, built in 1963. There has been an addition to the rear and in the crawlspace it looks as though the sill plate for one wall is sitting on top of pieces of 2x4. Is this allowable? Research (google) says it is, but I don’t think that’s right. My thinking is 1.) there’s no way to secure it to the block. 2.) The sill plate will eventually sag under the weight and lead to other issues. The first photo is an exterior of the section in question. It’s not long, maybe just over 10 feet. This must be something I’m destined to learn as yesterday’s inspection had the rim joist supported by masonry block piers that were too far apart. Welcome to Alabama.
Were there any foundation bolts or straps? I would certainly be on the lookout for how it is attached to the foundation.
I am seeing this as a joist or beam intended to span distances that is supported at intervals (where the shims have been placed) versus perhaps having better continuous support when originally installed. IMHO, if the beam is not significantly deflecting under the load and the floors above are level, then it is doing its job. However, if the beam is deformed and the floor above is unlevel, then those are deficiencies that should be corrected (perhaps as easy as adding shims to provide better support).
Morning, Anthony. Hope to find you well.
2x4 is fine.
Appears there are gaps between the sole and CMU.
Several Gaps between the sill and block foundation.
Several 1x6" & 2x4" shims appear to be causing gaps at the sill.
Vegetation/vines crawling between the sill and CMU blocks and 1x6" & 2x4" shim.
Crawlspace defects. Sorted Construction Debris atop the vapour barrier.
Recommend a licensed general contractor further evaluate and seal the sole plate CMU intersection, seal any gaps on the exterior of the foundation. Act upon any recommendations therein.
Sill plates must be pressure-treated or naturally durable wood and, while a 2x4 is the minimum, it must be wide enough to provide full bearing for the wall studs above it.
so the non-treated wood sitting on the blocks are not an issue? and the missing anchor bolts as well? i would have thought that they use those even in alabama but have never looked at or built a house there. but i suppose there could be anchor bolts not pictured that are attached. still, the wood touching blocks is not a good thing in wv.
Regardless of whether this structure is classified as a porch, deck, or conditioned addition, once it is physically attached to the dwelling it must be constructed in accordance with the applicable provisions of the International Residential Code.
Specifically, IRC R404.3 governs foundation wall design and support requirements, and IRC R403.1.6 outlines the mandatory anchorage of sill plates to the foundation. These provisions apply to attached structures to ensure adequate load transfer, lateral stability, and long‑term performance.
Local amendments or jurisdictional requirements may impose additional standards, but the minimum expectation is compliance with the IRC sections noted above.
It is not good in AL either :slight_smile:
This is another example of “test of time.” Those shims look original. In 1963, the builder decided it was easier to level the house with shims than to bother with a level block foundation.
Yup. We wouldn’t do it today. Today, it’s mostly steel shims and has been since I got into construction, although a few months ago, I saw a structural engineer recommend shimming the sill above a settled block foundation with wood shims and blocks.
If it is working, then…it’s working. On a 63-year-old house, those wood blocks appear to be working.
That porch addition does not look like a 63’ build to me. A lot more recent would be my guess.
@bcawhern1 there were no foundation bolts or straps. That went into the report.
Hey @bhoefer, what’s pictured in the crawlspace is the lower sill plate of an outside wall above. The photo showing the exterior of the home is the wall that is shown in the crawlspace photos. My question is; with the wall and roof supported above, are the blocks underneath the seal plate “allowable”? I would think that over time a transfer of the load would cause the sill plate to eventually sag.
Hey @tsayre3, the non-treated blocks are sitting on a metal flashing/termite shield, not on the bare block. It’s hard to see in the photos.
Hey @lhenderson2, the addition is relatively recent (within the last 20 yrs). Had it been older I wouldn’t have been as surprised as I was.
It seems like poor practice by the builder, likely trying to avoid the irregularities of the block wall. Those floor joists are sitting on the long grain of the partially supported plate and is a pretty likely split point if something shifts to far.
Yea that’s kinda weird, but IMO the nails from the rim joist into the ends of the floor joists are likely taking up most of the load, the joist spans are short, and/or most of the time people don’t load the floor to the design loads. If the joists are supported by that little lip of the sill plate only, then it might have already split. Just say it is not a recommended method of joist support and recommend some additional support. I would nail pieces of treated wood under the sill plates at the joists and call it a day.
  1. There is a metal termite shield(looks like galvanized) between the wood and the foundation so it’s not a problem. Zoom in and you’ll see
  2. Anchor bolts are not installed in a lot of older homes. Most of the time sill plates are just nailed into the foundation. The house has survived as the house is likely in a low seismic and low wind area, or it just got super lucky. You can recommend proper anchor bolts be installed, but likely no one is going to do it because of the cost and the low chances of failure.
doesn’t look like it to me but i wasn’t there…
Does it still make it to your report or is it a moot point?
It’s right there :zany_face:
I’d still make a point about it. I’d tell them it was common practice during the time period the house was built but the technology of anchoring the house to the foundation has improved and the benefits of installing anchor bolts and consider having it done as an improvement (obviously if you are in a decent seismic/wind zone you make a harsh recommendation to put anchorage in). This serves to give the consumer information about the way the house was built and as a CYA should some contractor come after you and say OMG ITS MISSING ANCHOR BOLTS YOUR HOUSE IS GOING TO SLIP OFF THE FOUNDATION!!!.
You know there is going to be some unscrupulous contractor that will say that. They might also say that anchor bolts are required by CODE and the installation is illegal. They will use things that are technically or partially true without context and sway the consumer to pay for retrofitting foundation anchorage. Imagine trying to explain to a lady who is stubborn as a rock and made up their mind such as the one in the other topic about the condensation on the hardie siding regarding why you didn’t tell her the house was missing anchor bolts.
Even if there is no contractor, most home buyers don’t know anything about houses nowadays. Guess what they are going to do? They or their technologically literate offspring will feed “missing anchor bolts” into AI and the AI will spit out that it is a significant structural defect and that the house will slip off the foundation during seismic or high wind conditions. There are also blah blah blah IRC CODE REQUIREMENTS that anchor bolts be installed at a certain spacing. Now the consumer is going to think the house is illegal OH NO!!!???
But the truth is the house is in a no or low seismic area and the wind loads are standard, and the house is only 1 story and surrounded by trees. So…did they really need to pay $3000+ for the additional foundation anchorage? Take the little old ranch in Anthony’s pictures, for the people actually buying the house to live in, do you think they have loads of money to spend on repairs? No. They might end up not buying the house due to the costs of the repairs because the seller is not going to pay for it. It sucks all around
