I am performing some practice inspections and noticed that there is no visible flashing around the water heater stack, bathroom vent, plumbing stacks and the kitchen exhaust vent. It appears as if they just cut a hole in the tile and then use some sealant around it. The water heater vent had no boot on it like you would see on an asphalt shingle roof. My concern is that over time the area around the roof projections will deteriorate and lead to water intrusion. Maybe the exhaust gas can condense and cause corrosion around the base of the stack? Any info or perspective on this would be appreciated.
These are common installations in this area. There are flashings specifically designed for these roof penetrations, which can be installed in lieu of the mortar/weather blocking in your pics, but (that cost more money to install) so, the only time I’ve ever seen them was on retrofits.
It looks like a repair was performed on the B-vent storm collar (this is a common roof leak area). The off ridge attic vents lack baffles/louvers across the front of the vents to help prevent wind-driven rain into the attic. It’s very common for the upper attic vents to not be properly installed (per the Product Approval/manufacturer instructions), those observations are made from the attic. Checking below all these areas in the attic for roof leaks is recommended.
The FRSA-TRI Florida High Wind Concrete and Clay Tile Installation Manual has the installation instructions for concrete and clay tiles in Florida.
Here’s an article about the changes in the most recent edition:
Florida Product Approvals can be found here:
It would be very unusual for the plumbing vent on a tile roof in this area to not have a lead boot installed. Which in your photo appears that it does.
Hi Dave,
Thanks so much for all the information and clarification!
