swimmingpool water heater on roof
Originally Posted By: JETDOC
I am a new inspector and I saw something that to me looked ok but was wondering if other people have seen it. The seller of a 7 year old home has a pump by his pool that pumped water to the roof through a flexable line that he had snaked across his roof and then down into the pool to heat the water. He had brackets nailed to the roof to hold the hose. He also had the nails sealed with caulk. I told the buyer it should be ok but I would check the attic every year or so to be sure no water is leaking in and to reseal the nails. The attic looked good and no water damage around brackets. Has anyone ever seen this and did I say the correct thing to my customer? Thanks
Originally Posted By: Inspect01
I’ve seen this method being used on several houses, and as far as I can tell, as long as the installation of the system was done properly, there shouldn’t be a problem. I think you were right in suggesting that they check the attic every once in a while. I could imagine that this might have a long-term negative effect, but haven’t seen one yet. Anyone else know?
Any penetration of the drainage plane is a potential moisture leak. Such penetrations should be kept to a minimum to reduce leakage potential. I have never seen this but can imagine some pool guy somewhere suggesting this as a cheap way to provide some added heat to the pool. Probably pushes it as a new style of “Solar Heater” without explaining the negative effects of nailing it to the room.
Erby Crofutt
B4U Close Home Inspections
Georgetown, Kentucky
www.b4uclose.com
Originally Posted By: jmyers
I would seriously question why they put it there in the first place. It would seem the place for any pool accessories would be next to, or as close to the pool as possible. I have come accross air conditioning units on roofs which seems to be a more acceptalbe practice, especially in older homes which did not originally have air conditioning.
Why did they place it there in the first place?
Joe Myers
A & N Inspections, Inc.
http://anii.biz
Originally Posted By: jhagarty
edited
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Joe,
Have you ever come accross any (solar panel heaters) down around West Chester? I can understand the solar panel, but just flexible hose attached to the roof. Sounds like they were just being cheap. Not good in my book. I have not seen any solar panel heater yet, just solar covers for the actual pool. Do you know anywhere I could get a look at one?
Joe Myers
http://harterindustries.com/Hi-Tecmanual/installation_manualpage%201.htm
Joseph Hagarty
[email protected]
Phone: 610-399-9864
Fax : 610-399-9865
Joe,
Thanks for the link. By the installation diagram they show on that site it looks like they only use the current pool pump and filter.
I have actually seen pools with the second motor for the robot cleaners. I have seen standard boilers used to heat pools. But I have never seen the solar heaters yet. Some day I will for sure, till then its nice to know what I am looking at.
BTW....I bet the roofers love these things.
Joe Myers
edited
Joseph Hagarty
[email protected]
Phone: 610-399-9864
Fax : 610-399-9865
Joe,
You stated it is 18 years old. How long are they supposed to last? Any idea? Please don't play the listing agent here and tell me "forever". icon_biggrin.gif
Joe Myers
edited
Joseph Hagarty
[email protected]
Phone: 610-399-9864
Fax : 610-399-9865
Forever only rings true for death and taxes…everything else dies when you least expect it or you can least afford it! icon_biggrin.gif
Joe Myers
