Originally Posted By: nlewis This post was automatically imported from our archived forum.
I was testing an outlet with a $10 three light/GFCI tester and it showed “wiring OK”. I turned off the wall switch to turn off the outlet and the tester then showed “open neutral”.
Does anybody know the reason for this? Speculation also welcome.
Originally Posted By: psabados This post was automatically imported from our archived forum.
Sounds like someone has switched the wires around. Using the switch to break the neutral connection. You still have 110 being supplied to the hot side of the receptacle. Next time that happens use a multi meter or idiot light and check to see if power is still supplied at the hot side.
Most likely homeowner or friend had to change out a broken switch
Originally Posted By: Dennis Bozek This post was automatically imported from our archived forum.
Larry…
As a matter of fact......how old was the house. Houses here that were done in k&t used a switched neutral for all lights and switched outlets. If the house has k&t chances are that is what you have. The only real danger in that is if someone goes to change the light bulb and grounds themselves as they touch the the inside part of the socket but then what are the odds of that happening. Nevertheless, if you feel it is a hazard then recommend that mr sparky changes it which would be a chore in itself for typically in the switch box there will be no hot just like in today's modern switching the switch box is either just a switch leg or contains no neutral.
-- This information has been edited and reviewed for errors by your favorite resident sparky.
Joe,
I didn't actually look at the switch to see if it was a 3 way type, because it was in a bedroom to switch a wall outlet.
Dennis is correct about the wiring being done by Mr Homeowner. For example, the panel box was crammed full of all tandem breakers and no GFCI outlets in a brand new kitchen.
