Attached is a photo of 50 year old T111 siding with damage. I have seen minor instances of this but it’s all over this home. Is this decay in the layers under the exterior layer, woodpecker damage or what? Being so linear, it seems to be failure of the lamination.
Looks like classic woodpecker damage. They won’t stop until they find the bug that they think is in there.
Woodpecker. Lucky if that’s the only damage.
I agree with Jeff. Woodpeckers will circle the trunk of a tree, creating a stripe all the way around. This is what that would look like on a flat surface.
Yes, woodpeckers were my first thought, Thanks for the affirmation guys.
it would help if they put a coat of stain or paint on it every hundered years or so
Well only 50 more to go, I’ll recommend ![]()
I was thinking, Hunting impact marks due to the size or Xylem Well holes due to the shape of the hole and vertical alignment.
Here is a link to 10 Types of Woodpecker Holes and Other Woodpecker Sign on Trees.
I’d say that’s the culprit
Yellow bellied sap sucker!
I concur on your hypotheses. Nice work, Steven.
This is what I gleaned from AI.
A yellow-bellied sapsucker can damage siding by pecking small, regularly spaced holes in a horizontal pattern.
Feeding behavior:
Unlike other woodpeckers that search for insects, sapsuckers primarily feed on the sap that leaks from the holes they create.
How to manage sapsucker damage:
Visual deterrents:
Install reflective objects like aluminum foil strips, shiny discs, or Mylar tape to scare the birds away.
A little T1-11 trivia - OP’s picture is the real stuff. In my neck of the woods anything with vertical grooves gets called that but it’s often incorrect. The name comes from the distance between high and low spots. The low areas/grooves are 1" wide and the high/outward parts are 11" inches. Hence, the T1-11
I store up lots of useless information. Finally got to use some! Thanks for the recognition.
Great to meet another “god of useless information.” ![]()
