Does the piping that extends to the floor need to be soldered? In the pic it shows the NEWLY installed T and P valve and piping…the coupler is NOT soldered…it is tight of course…but not soldered…shouldn’t it be? Seems to me that it can come off and then it wouldn’t be 6 inches from the floor anymore eh?
Should be Tony…
You could braze it.
In a year I could
How did you do today Tony…Good?..I’ll bet so!..
I wouldn’t sweat it (no pun intended). The pipe should never be “pressurized” so no real issue as I see it.
NO to the code checks…but I am working on it.
AS for how I did…check my other posts Dale…and more to come I’m sure…I’m a bit worried…do you think I can talk the SE into letting me go with him as an interested 3rd party? (you will have to read my other posts to understand this)
I don’t see why not…why would he care.
You should find a retired or readily accessible engineer who you are able to call for things of this nature.
If you ever start doing Technical Inspections they are handy to have come to the property for about $150.00 (here anyway).
The engineer who works with me on Commercial Buildings is retired but still holds a current license and loves getting out to see things of this nature.
An engineered guess is a third disinterested party…when he is just working for basically the client.
His small report will keep you out of court…inexpensively.
what about the parts falling apart? threw normal bumps, or if the TPR pops open and then the part get blown off? i’d recoment securing it in some way shape or form. either solder with a wet rag behind it, or braze it, or maybe some sort of cemical compound? it doesn’t have to be water tight. i don’t know, but i’d like to be sure.
You could argue that point Jay, but you would be hard pressed to prove any requirement for securing the joint.
I would have checked it by hand to determine its integrity. If it came off easily, I would certainly note that it needed repair/correction.
That is how I realized it wasn’t soldered…I spun it in my hands I should have mentioned that in my initial post…sorry
In that case, it’s certainly improper. I would have taken a picture with the lower portion removed.
Why did this thread get moved? I specifically posted in members only area so that my clients wouldn’t find my post and realize I was talking about their home… sigh
Plumbing Contains discussions about plumbing.
Oopps…
Googles robots will not know what a T and P valve piping is…won’t rank very high, page wise…
I never saw it in the MO section. Are you sure it was posted there? Many technical posts are made in the MO section and they don’t get moved.
psst…I guess I am paranoid that I will type something stupid and they will find it when searching my name on google or something…I have a propensity or a predilection for saying stupid things…see what I mean?
no I’m not sure about anything today…except that I hope my next inspection feels better than this one…I felt good until I started asking for advice…and the realtor called me…
It is quite possible I put it in plumbing…but I am 99 percent sure that I put it in MO…
What did the realtor call you?
Just the fact that he called me to let me know the clients were upset after the inspection…
Ha Ha Ben!
