Tar Roof Slope
Originally Posted By: Kevin Blackwell
This is Kevin from Houston,TX
What is the required slope for proper drainage on a tar roof only?
Assuming you mean a built-up roof, then 1/4"vertical in 12’ of run
Originally Posted By: jpeck
A built-up roof can be dead level, as long as there is no ponding water.
It 'should' have a slope to promote better drainage, but a built-up roof is approved for dead level flat roofs. Depends on the asphalt used, and on a flat roof, you would use 'dead level' asphalt for hot mopping.
Jerry Peck
South Florida
The IRC requires the slope on built up roofs to be al least 1/4" per foot (2% slope) per R905.9
Robert O’Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
From the 2003 IRC.
R905.9.1 Slope.Built-up roofs shall have a design slope of a minimum of one-fourth unit vertical in 12 units horizontal (2-percent slope) for drainage, except for coal-tar built-up roofs, which shall have a design slope of a minimum one-eighth unit vertical in 12 units horizontal (1-percent slope).
Okay, the IRC does not have dead level slope, but it gives the option down to 1/8" per foot slope.
I am a firm believer that dead level flat roofs are how architects try to get even with everyone else. They KNOW it is virtually impossible to make a dead level roof not pond water, but, hey, that is not their problem. Their line on their drawing is straight and flat, why can't you make the roof that way?
Jerry Peck
South Florida
