Originally Posted By: wrobedeau
Most compressors are hermetic and meant to contain gas on the suction side of the compressor which is the metal can containing the compressor. In cool weather refrigerant migrates to the compressor and condenses as a liquid. Turn on the cooling and the liquid is drawn into the compressor resulting usually in damage to the valves. It can also lock the compressor up to where it cannot be started. This can be over come if a crankcase heater is installed on the compressor to provide heat to drive the refrigerant out. Most domestic systems do not have crankcase heaters.
Automotive compressors are open. The liquid is usually contained in the condenser which is in front of the radiator. When cool outside more liquid goes to the condenser. Most also have some type of accumulator ahead of the compressor. There is considerably less chance of liquid getting to the compressor.
Bill Robedeau
