Testing
What test can be done on a propane supplied furnance that has no propane?
Turn on the fan…
Yea, turning the fan on was the only thing I could think of
too.
At the time of the inspection …:smiley:
Why bother, it needs to have fuel, to be turned on to check for function. Write it up :smiley:
Ditto. How can you inspect it if there is no fuel. All you can report on is any visible condition you see. Then write: have gas company fill the tank and have the system tested by a qualified contractor. Sure does limit your liability.
