The Flue Goes Here
Are you sure?
measur twice, cut once, then check the print.
I think the exhaust is more important than the Truss support…Fantastic work.
They could have (at least) cut that hole for proper clearances.
There is proper clearance at the cut trusses, though.
:shock: :shock:
Damn, :shock::roll:
1961 charmer, I punted on the pool and told them to get pool contractor. Not too bad overall. I had a trainee with me and he did not see this.:frowning: I did a double take and crawled around the other side for a better photo. Its always something isn’t it.
At least you don’t have to worry about snow load.
Good photo Brian…:smiley: …1961 Charmer…:smiley: :smiley:
Hmmm A load bearing FLUE! :D:D
all ya need to do is jack up the house, push it over about a foot, and just fill in the extra with spray foam. (that stuff rocks)
