Will it vacuum the lawn?
:D:cool:
I’m gonna get me one of those.
Is it easy to clean?
Yes very easy to clean and does a good job
I hear you can get a robot that cleans the Roomba for you now.
I thought 3,4,5 had been mentioned before Nick, but anyways, this is what I have been using for layout for years since they came out.
I couldn’t relate it to your question.
Nice piece of equipment… Do you have further information: Make, model?
Thanks in advance!
Regards,
Pat
This is the one I have used for years.
https://www.calculated.com/prd103/Construction-Master-5-4050-Construction-Calculator.html
Thank you Marcel!
Found it at the local building centre!
Best regards,
Pat
So the question is, you’ve done all the paperwork and designed the building how does the calculator help you build it that way?
Somewhere along the line one has to translated the theoretical to the practical. I suspect no three button tool is going to help you there.
Back to plumb, level, square and measure, methinks.
Same as the Greeks did, the Egyptians before them and the Babylonians before that.
