The scientists have come through again
Congratulation’s the space craft has landed .
The European Space Agency’s unmanned Rosetta probe successfully released a lander toward the surface of comet 67P/Churyumov-Gerasimenko today, putting it on its final seven-hour journey to a historic rendezvous with the fast-moving lump of dust and ice.
The audacious landing attempt is the climax of a decade-long mission to study the four-kilometre-wide comet, which is travelling at 66,000 km/h. It is also the end of a 6.4-billion kilometre journey on which Rosetta carried its sidekick lander Philae piggyback.
“It’s on its own now,” said Stephan Ulamec, Philae lander manager at the DLR German Aerospace Center. He said that “we’ll need some luck not to land on a boulder or a steep slope.”
The Rosetta spacecraft’s parting image of Philae as the lander began its seven-hour descent to the surface of the comet shows the probe with its three legs - its landing gear - deployed. (ESA)
If successful, it will be the first time that a spacecraft has landed on a comet. Confirmation of a landing should reach Earth by about 11:03 a.m. ET. That will have been half an hour after the landing actually happened, due to the amount of time it takes data from the spacecraft to reach Earth.
ESA announced early Wednesday that the 100-kilogram lander’s active descent system, which uses thrust to prevent the craft from bouncing off the comet’s surface, could not be activated. Instead, the agency is relying on ice screws and a harpoon system to secure the lander.
Hours later, mission controllers clapped and embraced as the lander’s separation was confirmed.
Philae took this snapshot of the Rosetta spacecraft (upper right, with solar panel stretching into middle) shortly after separating and beginning its journey toward the surface of the comet. (ESA/Rosetta/Philae/CIVA )
“Philae has gone — it’s on its path down to the comet,” Rosetta flight director Andrea Accomazzo said. “We are all glad that it worked flawlessly in the past minutes.”
About two hours after the separation was confirmed, scientists said they had re-established contact with the lander, as expected. “Now we can follow it on its descent,” said Paolo Ferri, head of mission operations at ESA.
The washing machine-sized lander is supposed to drift down to the comet, and latch on using harpoons and screws. During the descent, scientists are powerless to do anything but watch, because the vast distance to Earth — 500 million kilometres — makes it impossible to send instructions in real time. It takes more than 28 minutes for a command to reach Rosetta.
Quite the achievement.
What ever happened to the US space program?
http://www.cbc.ca/news/canada/saskatchewan/ground-stations-built-by-sask-firm-play-big-role-in-historic-comet-visit-1.2828928
**Ground stations built by Saskatchewan firm play big role in historic comet visit
A little-known Canadian company is playing a big role in the European Space Agency’s Rosetta mission, the first in history to rendezvous with a comet.
The agency is hoping to drop a lander, the size of a small fridge, on the comet’s surface in the coming days — a feat that has never been tried before.
The mission is being carried out with help from Saskatoon’s SED Systems, which built three ground stations the space agency uses to communicate with the Rosetta spacecraft.
The orbiter is currently circling Comet 67P/Churyumov-Gerasimenko, which was named after its astronomer discoverers.
Helping understand the origin and evolution of the solar system is the mission’s prime objective.
“SED has been involved since the delivery of the first antenna back in 2001,” Denis Sirois, the firm’s business manager, said in a recent interview.
‘The time it takes for the signal to leave the spacecraft and arrive on Earth is somewhere between 30 and 50 minutes.’- Denis Sirois
The first tracking station was built in New Norcia, which is near Perth in Western Australia. The two others followed, in Cebreros, Spain, in 2006 and in Malargue, Argentina, in 2013.
The total cost of the three stations and their 35-metre antennas was between $80 million and $100 million.
Company officials and scientists are now eagerly awaiting this coming Wednesday, which is about three months after the 2900-kilogram spacecraft first arrived at the odd-shaped Comet 67P/C-G.
The plan is for the orbiter to release the 100-kilogram lander.
The Philae lander, named for an island in the Nile, will then attempt to latch on to the icy space body using harpoons fired into the surface.
The shape of the comet, which has a ‘head’ and a ‘body’ separated by a narrow neck, has been likened to that of a rubber duck.
Even though it’s a relatively small object of about four kilometres in diameter, the comet is moving at speeds up to 135,000 km-h.
Spacecraft communicates from billions of kilometres away
Sirois pointed out that since the Rosetta orbiter was launched in March 2004, communications have had to be planned “days and weeks” in advance.
“The furthest away that the spacecraft had been was somewhere in the neighbourhood of a billion kilometres,” he said from his office in Saskatchewan.
“So the time it takes for the signal to leave the spacecraft and arrive on Earth is somewhere between 30 and 50 minutes.”
Sirois says when the Philae lander touches down, its signals should take about 30 minutes to arrive back on Earth.
And that in itself poses an interesting scientific challenge.
“It’s a little bit like Wayne Gretzky used to say: 'You don’t pass the puck where the player is, you’ve got to pass it where he is going to be,”’ Sirois said.
“It’s the same with sending commands up to this thing because in that 30-minute timeframe — between sending the command on Earth and its arriving at the spacecraft — the spacecraft has moved considerably.”
The SED’s three ground stations are under the control of the European Space Operations Center in Darmstadt, Germany.
Sirois said it wasn’t easy for the Saskatchewan company, with 250 employees, to win the contract to build the first one in 2001.
“The competition was fierce, there was an Italian consortium (and) other European bidders who wanted in on these stations as well and, of course, they had some of the capabilities to do it,” he said.
But he said a co-operative effort involving his company and the Canadian Space Agency paid off. Canada also takes part in some European Space Agency programs.
“Because we were quite unknown, it was even more difficult to convince them (ESA) that we had the capabilities to do it,” Sirois said.
“But, based on our heritage and our experience, that allowed us to get to the table.”
SED has had a history of building ground stations, but mostly in the telecommunications sector.
“After the first contract, we had basically passed the test with ESA and they were now confident in our capabilities,” Sirois said.
SED still had to compete to get the contracts for the two other stations, but it had an advantage over its competitors after it built the first one.
The ESA mission is named after the Rosetta Stone, a slab of volcanic basalt found near the Egyptian town of Rashid (Rosetta) in 1799. The slab, with three languages, provided historians with the key to an ancient civilization.
One hell of an accomplishment!!
I agree and love to see things like this work out a big thanks to all involved .
I hope they get much information and ideas from this endeavour .
Fantastic !!!
The space program funds are being used to stabilize the Iran, Irag and Turkey
Oh I thought it was for Banker bailouts, increased wefare checks and funemployment extensions.
silly me.
