The virus is not a living organism
The virus is not a living organism, but a protein molecule (DNA) covered
by a protective layer of lipid (fat), which, when absorbed by the cells of
the ocular, nasal or buccal mucosa, changes their genetic code. (mutation)
and convert them into aggressor and multiplier cells.
  • Since the virus is not a living organism but a protein molecule, it is not
killed, but decays on its own. The disintegration time depends on the
temperature, humidity and type of material where it lies.
  • The virus is very fragile; the only thing that protects it is a thin outer
layer of fat. That is why any soap or detergent is the best remedy, because
the foam CUTS the FAT (that is why you have to rub so much: for 20 seconds
or more, to make a lot of foam).
By dissolving the fat layer, the protein molecule disperses and breaks down
on its own.
  • HEAT melts fat; this is why it is so good to use water above 77 degrees
Fahrenheit for washing hands, clothes and everything. In addition, hot water
makes more foam and that makes it even more useful.
  • Alcohol or any mixture with alcohol over 65% DISSOLVES ANY FAT, especially
the external lipid layer of the virus.
  • Any mix with 1 part bleach and 5 parts water directly dissolves the
protein, breaks it down from the inside.
  • Oxygenated water helps long after soap, alcohol and chlorine, because
peroxide dissolves the virus protein, but you have to use it pure and it
hurts your skin.
  • NO BACTERICIDE OR ANTIBIOTIC SERVES. The virus is not a living organism
like bacteria; antibodies cannot kill what is not alive.
  • NEVER shake used or unused clothing, sheets or cloth. While it is glued to
a porous surface, it is very inert and disintegrates only -between 3 hours
(fabric and porous),
-4 hours (copper and wood)
-24 hours (cardboard),
  • 42 hours (metal) and
-72 hours (plastic).
But if you shake it or use a feather duster, the virus molecules float in
the air for up to 3 hours, and can lodge in your nose.
  • The virus molecules remain very stable in external cold, or artificial as
air conditioners in houses and cars.
They also need moisture to stay stable, and especially darkness. Therefore,
dehumidified, dry, warm and bright environments will degrade it faster.
  • UV LIGHT on any object that may contain it breaks down the virus protein.
For example, to disinfect and reuse a mask is perfect. Be careful, it also
breaks down collagen (which is protein) in the skin.
  • The virus CANNOT go through healthy skin.
  • Vinegar is NOT useful because it does not break down the protective layer
of fat.
  • NO SPIRITS, NOR VODKA, serve. The strongest vodka is 40% alcohol, and you
need 65%.
  • LISTERINE IF IT SERVES! It is 65% alcohol.
  • The more confined the space, the more concentration of the virus there can
be. The more open or naturally ventilated, the less.
  • You have to wash your hands before and after touching mucosa, food, locks,
knobs, switches, remote control, cell phone, watches, computers, desks, TV,
etc. And when using the bathroom.
  • You have to Moisturize dry hands from so much washing them, because the
molecules can hide in the micro cracks. The thicker the moisturizer, the
better.
  • Also keep your NAILS SHORT so that the virus does not hide there.
What exactly defines life?
I dunno!
Maybe if you can kill it with a fork. …
or the government
IMHO if they don’t have mitochondria and/or ribosomes , then they ain’t living.
Great info, Marc!
Thank you.
Thanks Marc! Spread the word… stay safe folks.
I’m out lickin’ door knobs and sneezing on everyone. :rofl:
You’ve got the Yankees beat! YEAP!
From soakin’ to lickin’, you a busy man! :grin:
Awesome information Marc! Can you site the origin of this. I would like to post it on my other places of social media. There are so many people driving around wasting PPE because they don’t understand what they need to do to protect themselves and when.
You may want to read this, before spreading the above information any further…
I did not state the info came from Hopkins.
Irene Ken physician, whose daughter is an Asst. Prof in infectious diseases at Johns Hopkins University
I know you didn’t. I had liked the post you shared! :grinning: I stumbled on the above when searching for a link to it. Did you read to the bottom?
My info did not come from Hopkins.
Keep up the shit & you will be reported to Robert Young for illegally using WAAAAY too many thumbs ups!
Ooooops! :grin:
…I thought this was an Ohio thing only!
Apparently, listerine has only about 26-27% alcohol. Not sure where they got 65%!
Let’s hope this continues!!
https://fdoh.maps.arcgis.com/apps/opsdashboard/index.html?fbclid=IwAR2kmdqTo4U99mPqwzrZrGj6AGk3jtaVntWEZzuRuuuCKB9aFJsjosN6lwM#/8d0de33f260d444c852a615dc7837c86
Stop It Junior!
