Thermal Camera Suggestions, Let's be civil and professional please
Hello InterNachi Team. I am prefacing this post as the last one I saw asking for thermal information devolved into a bunch of personal attacks back in 2017.
Technology advances, costs come down. I am finishing up my Nachi training modules so I can change up from being the pound of cure in construction to becoming an ounce of prevention via inspections.
That being said. I am not looking to become a professional thermographer. I am going to get the Thermal cert from Nachi.
I am looking at thermal as another arrow in the quiver to work in tandem with moisture meters, visual inspection, etc to have a well-rounded inspection.
Also, as a former industrial design tech guy, I am aware that any thermal imagers produced in China has had their tech stolen and replicated in “knock-off” brands because this is what they do.
Thanks for bearing with me. So as we are now almost a decade down the road.
What brands/models are you currently using in your practice with good results and happy clients.
Please include makes/models rough tech specs like memory, image resolution, etc.
Please, No hating on others as I view that as a direct violation of our agreed upon SOP’s and COE.
We agree to use our knowledge to help one another and further develop excellent inspectors.
Thank you.
Sincerely,
Jeremy Spring
If you plan to use your imager for moisture, you need both a good imager AND the knowledge of how to create the conditions that allow the imager to detect moisture. Good imager and good knowledge. Get training and you will learn how to choose a good imager for your planned use. IR is more than point and shoot.
That said, I use my imager primarily for energy audits. I don’t use it for home inspections, except sometimes to confirm in floor heat operation. IMO, there is too much client misunderstand of what an IR imager can do and a lack of understanding of the limitations. I don’t want to own those liabilities for a home inspection.
If you want to report insulation condition and insulation voids, it’s good for that. I choose to not include that in my home inspection reports.
That said, I have an older Fluke TiR1. It allows for adjusting range and span. It also has a number of palettes, useful for different applications. A good imager also has a good lense. That’s what you are paying for.
Morning, Jeremy. Hope to find you well and in good spirits today. Welcome to the InterNACHI form.
Let’s be civil please. Love it. Nick Gromicko said of me, New Eyes are Fresh Eyes over 15 years ago. Never forgot it.
The incivility you refer to was proliferate and aimed/trained on certain members. When I started using the message board Roy Cooke senior was being lambasted by about 15 members continuously. I came to his defense asking members to stop the nonsense. It took almost a year for things to quite down. Roy Cooke Senior was the first inductee to InterNACHI hall of fame and aided the CMI designation in Canada. Sterling reputation. Chair on Ethics Committee at OHIA. Use to pick up Nick Gromicko, the founder prior Nick giving meetings in Southern Ontario. Glad to be his friend.
I still have a member that has stalked my posts for 15 years. Formal complaint leveed.
Hang tuff buddy. Water off a ducks back. Make complaints to the proper authorities at InterNACHI under COE rules.
Lots of models out there by several manufactures. 500 to 700 dollars for 360x240 resolution. SEEK 320 x 240 Resolution
Flir have reasonable prices for thermal imaging models 240x120.
Fluke 120 x 90 infrared resolution
I am selling my HI equipment. I have a Fluke Ti 300 240x180 resolution. I paid >< $10,000. Sell for $1,500.00 No issues. If any one is interested.
Lots of answers coming your way.
Good luck.
I’ve been using a HikMicro Pocket 2 for just over 2 years. For what I use it for, it’s just right.
I recently reviewed a Thermal Master P2. This is an Android only camera that plugs into your phone. I carry this as my backup now. Again for what we do with it, it’s probably enough. It’s also fairly inexpensive.
I looked at the C5 from Flir and for the Cost, the HikMicro P2 has better specs and is cheaper.
Good Luck
Seek has a line of reasonably priced equipment.
Moisture: My recommendation is to utilize a surface contact moisture meter. I do utilize that during home inspections. If you are suspicious, test at all the suspected spots. Yes, you might miss something. Setting the house up to detect moisture using IR takes effort and time. Will your clients be willing to pay you for that added work?
Those big blotches you see on IR images are there because of temperature difference. That temperature difference is not always present. If no temperature difference, no big blotch on the IR image. However, the moisture meter will tell you that surface has excessive moisture.
These are two images from work to document and locate moisture issues. The conditions were set up so evaporating moisture on the drywall shows up on the imager.
I also have to add; one needs to have an imager capable of adjusting the emissivity.
Again, you learn all this during your training. During my training, we had a number of imagers to use, hands on. That’s the kind of training you want to obtain.
There are several others on this forum who are much more experienced and qualified in IR than I am. Listen to those individuals if they post here. Ignore the trolls.
I have been considering the HikMicro as my wife showed it to me from another well known inspector’s reels. I was comparing to the flir one that plugs into my android as well. Thank you for being another person who has seen fit to add this to their inventory.
Thank you for bringing up a selection including SEEK, I am unfamiliar but I will look into them.
I appreciate the input.
Thank you. I prefer to let trolls live under bridges and not give them headspace. I’m getting too old to bother with them, and I’d like to follow my own advice of doing my best to be civil and professional.
Afternoon, Michael. Hope to find you well.
Decent thermogram.
How did you adjust your thermal camera to allow evaporating moisture/evapotranspiration to show up on your imager.
From what I recall, evaporating moisture leaves a cooler than ambient temperature signature of roughly up to 1.5 degrees F.
As well if those are metal studs or any metal behind the wall board may likely indicate false positives on moisture meters.
I bought a Flir E6 years ago…it is fairly basic, but the resolution is better than most I have seen.
I have dropped it from varying heights, no drama.
The thing just works.
I have had no dice on the wifi connection working, but I upload images when home via USB.
My only gripe is that the first power up can sometimes take 60 seconds or so.
Maybe start with on like this, with many used out there and upgrade when you think you are in need of a step up.
I have a Hikmicro B20 and it’s great. I use it in the same capacity that you’re planning on and am really happy with the purchase. At the time I bought it, it was $500 and had better specs than the comparable Flir. Not sure if that’s still the case. The Wi-Fi and Hotspot functions are awesome. I connect it wirelessly to my phone and through the app I can view the cameras screen in real time, take pics and videos, and they’re all automatically saved to my phone (as well as the camera’s Micro SD card), which saves time having to download everything separately from the camera.
Fan running all night before making the images. This is the north side of the building after a cold night. We had two days of heavy rain ending the afternoon before making the images. There is not a lot of drywall surface temperature difference. I changed the palette and played with emissivity. The surface was not painted. The “paper” setting was more pronounced.
This building has a 0.5/12 shingled roof. Siding is T111 sheets with no house wrap or felt. The owner is exploring EPDM rubber membrane roof and good roof edge flashing.
I see a lot of people shying away from the tool (or recommending a cheap one) because of the legitimate concern that presenting the data to the client or charging for the service, or promoting it is a source of confusion/liability. Don’t do any of those if you don’t go all in! As I’ve said before, I break mine out on the sly and use it as a set of super eyes. I run the showers for 10-20 mins, but a very slow drip isn’t necessarily going to make a great stain in the ceiling I’ll see with my nakeds. I’m not sure how I’m going to quickly scan a ceiling with a moisture meter, either. Even a cheapo IR cam will generally find even mildly wet areas though. Use the HVAC to make a temp difference toward the end of the inspection - that helps a bunch. I bought the Topdon TC005 because it had better resolution and dependability than the Flir that plugged into the bottom of my phone. I forget how much I paid, but it wasn’t an amount I need to remember. Bag it, use it quietly, be a hero.
I continually play with palates. Main palate: Gray scale. Once an anomaly is found, after adjusting camera angles and vertical positions for the best shot I go through some pallets. I have 13 to choose from.
Isn’t emissivity how efficiently a material emits thermal radiation to a black body - perfect emitter?
Wouldn’t it be expected moisture-related temperatures on surface readings?
Emissivity Table.
My Fluke Ti 300 settings for moisture detection, in drywall, I adjust my temperature scale to a range suitable for the expected moisture-related temperatures on surface readings. As expressed, looking for changes up to 1.5 degree F cooler. I can adjust emissivity and other reading with Flukes proprietary software SmartView at home in my PC and use my 27" inch HD screens. Then snip and paste the images into a report or create a IR report.
Thanks for the discussion Michael.
For basic home inspection needs I would recommend the HIK Micro. Several years ago, I purchased my Flir E6XT and it has been a great camera. Along came the HIK Micro, and for a fraction of the price the resolution is better than my Flir. When and if my Flir dies, I will look into the HIK Micro. Also, Bill Fabian at Monroe Infrared is a tremendous resource when it comes to selecting and learning the in’s and out’s of cameras. Reach out to him and he will be happy to help with your decision making.
Whatever you choose, use your InterNACHI discount when you buy it.
If you haven’t already bought a thermal camera, I would recommend looking for an in person class to take your certification. I have nothing against the inter Naci certification class, but if you attend a thermal imaging class, the instructors will have a lot of information and sometimes other cameras that you can look at. They will describe the differences in them along with the prices. You will be able to get some hands on time with different thermal cameras, and make a decision to get the best thermal camera you can afford for your budget.
I’m very pleased with Hikmicro M30. It’s a fantastic camera. The salesman at Monroe’s claimed it was a better bargain than competitors and I believe him now. I’ve performed surveys since the early 90’s in the Navy and commissioning power plants/substations using the old wood handle Panasonic, and of course Flir. I highly recommend the M30 for value. Can also be used at night on property locating whatever in the dark, pretty far away.
