Just curious, does anyone use tic sheets?
Do what you are comfortable with and print your own based on your report template.
Do not copy others unless you are using the exact same template and software.
No, ticks are only an issue here during the summer, so I don’t bother. :-;;
Is it kinda like a dryer sheet that you place under your armpits to distract ticks?,.,
Sorry couldn’t resist. I agree with Bob, if you borrow make sure it is lined up with the same software template you use.
Dat is why I said only if comfortable.
Some feel like sandpaper.
