Some of the stucco contractors here have to be some of the dumbest bastards on earth…:twisted:
Frankly it is simply unbelievable…:shock: :shock:
Dale,
Thats an UNDERSTATEMENT!:cyclops: ](,) ](,) ](,) ](,) ](*,)
Dale,
If the stucco connnntractors are getting away with all that crap what are they covering up?
Split Warped Fingerjoint 2x4’s with holes drilled in the joints…(:{
OSB (shear walls only) water logged…(8')
No window flashing…:humph:
No flashing at all…:-s
No chicken wire…:-&
No barrier…:-k
No Brainers…:?
No Kickouts…:idea:
No drainage planes.
:roll:
For the Bong water…![]()
Come on guys please do not get me started!
Take a deep breath Dale. Let it go!:mrgreen:
Hey brother…I didn’t pull them pictures on page one here from a Bong…O:)
If the dang stucco produces a free buzz, I’ll lay underneath it with a funnel in my mouth. :margarit:
I shut down the rating system after I got reddies for saying good morning.
Duffy, got your back for Erol
Weeps through the foundation/sill plate a lot of the stucco on this one terminated below grade…Doh!!! #-o
When it does that, no screed is required, right? -o<…and where it was above grade they skimmed some parge/base, embedded EIFS mesh and applied the top coat…for that nice consistent finished look…only problem was it was all delaminating like your shots
wanted you to feel and see the love
it ain’t just in your neck of the woods
we just don’t have quite as much for them to screw up
What drainage planes?
What flashings?
http://www.badstucco.com/Leaks101_files/frame.html
It is a good thing Dale does not get the moisture that others do around the country!
In east Texas, these houses would already be filled with water from all the hard rains and half of the poor outer coating would be washed off.
Does the general/builder/carpenter have to be licensed in TX. (Not in OH)
Bong water my a**
The dang thing comes with a bong too. Here’s the screen for it.
Erol,
Good info now how do we get them to read and do this? :roll:
OK well you got another greenie … you just don’t see it. ![]()
Dale on the other hand … will have to wait! You must spread some Reputation around before giving it to dduffy again.
This is a travesty and is what gave EIFS a bad reputation. This is exactly why we created a 7 hour DVD training program to train inspectors which is obvious you know what your doing but more importantly contractors to effectively repair these type of problems. If you ever need a repair contractor, feel free to call upon our independent MoistureFree Contractors. I hate seeing these problems. They shouldn’t happen.
