badair
(Barry Adair, TREC#4563 EIFSTX#39)
January 29, 2008, 12:42pm
#1
I sat back and relaxed then flushed
Tank was not bolted properly on all toilets in this three bath condo, they all gushed when flushed, but only when you sat back
Unfortunately homeowner used them this way and floors/base/walls were damaged badly…watch how you inspect
cduphily
(Chris Duphily, Level II Infrared Thermographer #8355)
January 31, 2008, 1:08am
#2
Just mark it down as a bidet.
mcyr
(Marcel Cyr, CMI)
January 31, 2008, 1:18am
#3
badair:
Barry, If you are going to use one of those things to relax and relieve, it is not designed to be a lounge chair, you probably over exercised the tension of the bolt connection between the tank and the flush. ha. ha.
You should differ from using the sellers property to relieve yourself on paid time.
Marcel
dedwards
(Doug Edwards)
January 31, 2008, 2:09am
#4
It was a “stress” test.:mrgreen:
bkelly2
(Brian Kelly, AZ Cert. # 60234)
January 31, 2008, 3:59am
#5
Who here has used the facilities before making sure the water is on???
cduphily
February 1, 2008, 9:04pm
#6
Always flush first! :lol:
mcyr
(Marcel Cyr, CMI)
February 1, 2008, 10:02pm
#7
bkelly2
February 2, 2008, 4:28am
#8
Early on I had to go to the convience store and buy 4 gallons of water.
