system
(system)
January 30, 2005, 12:00am
Originally Posted By: bking This post was automatically imported from our archived forum.
I was wondering what the commonly used, newer pipe material is from the shutoff valve to the toilet tank. It is light gray with compression fittings.
Surely this is not PB ? PEX hopefully....
Common in new homes in NC and SC and other areas I assume too.
thanks for info
Bruce King
system
(system)
January 31, 2005, 12:00am
2
Originally Posted By: Dean Call This post was automatically imported from our archived forum.
We mostly use the light gray or white PEX supply tubes with plastic compression ferrules.
system
(system)
3
Originally Posted By: dhadler This post was automatically imported from our archived forum.
Same as above, plus the stainless steel braided hose with rubber washers built in…they’re great, never leak at connections even at first attempt by beginners
– Darrell Hadler
Five Star Home Inspections
Medicine Hat, Alberta CANADA
system
(system)
February 1, 2005, 12:00am
4
Dean … are you sure the grey plastic connectors are PEX? What manufacturer, as I’m not aware that PEX is currently made in a gray color …
– Robert O’Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
system
(system)
February 2, 2005, 12:00am
5
Originally Posted By: Aaron This post was automatically imported from our archived forum.
Stainless steel hoses > everything else
Nothing else to discuss
