Tools, equipment etc
Just getting through through the certification process. Looking for suggestions for the tool box, ladders, etc. I have tools but anything that has made your job easier that you didn’t have. Be detailed as you can or not. Happy to get some feedback. Thank you in advance.
I would go lightly on the tools in the beginning. Ladders, obviously, with at least one being an extension tall enough to reach an expected roof. Good flashlight, 3 prong electrical tester, camera.
Buy a wiggy (solenoid electrical tester) and learn to use it. A DMM is virtually worthless for this profession.
Remember this is a non-invasive inspection! You operate with normal controls and observe. You don’t repair or diagnose.
List of Home Inspection Tools and Inspector Safety Equipment - InterNACHI®
Agree with Bob. Get a good flashlight. Minimum 2000 lumens. They are cheap these days. BTW, the 100,000 lumen flashlights for twenty bucks are scams, but most will be around 2000 lumens.
One thing I use every inspection is a small lantern type light. You can illuminate larger areas in attics and crawlspaces. Sometimes focus on one specific area is too limiting. Check out Fenix products.
Thank you
Todd Simpson
Costco’s got some great flashlights I have a 7000 lumen one that I use for crawl and attics. I use a 1500 lumen for other areas that aren’t so huge (mainly under sinks). Flashlights have come an incredible distance in the last 25 years. The 7000 lumen Costco one was less than $40 IIRC.
I really like an infrared thermometer and/or camera but be careful with the camera as you can raise more questions than you answer and piss people off. I mainly like it for checking heat registers.
A drone is nice for roofs but it’s a poor substitute for actually walking/touching the roof. Also nice for getting a look at the tops of chimneys.
3-prong outlet tested (without the GFI test button), voltage sniffer. I say no GFI tester because remote testing will just get you into trouble. You’ll click off an upstream GFI somewhere and not be able to find it. Sellers get pretty upset.
One thing I forgot was a 12 in one screwdriver. I have a Black and Decker rechargeable screwdriver but rarely use it. The 12-1 can be found in any electrical department of big box stores or jobbers. Easier to carry and does more things than the electric version (has more bits). You’ll generally only use it for electrical panel covers, but it handles common hex heads as well (HVAC).
As far as ladders and roofs, attic access, etc,…
Get a tall Xtend+Climb for outdoors, a shorter, lighter one for indoors. Get an aluminum 3-step stepladder. That will cover 90% of inspections (at least in my area).
Get a tall combo/multi-position A-frame ladder and another shorter one for the 10% of times when the Xtend+Climb doesn’t work.
Add a drone or a camera pole if you want to have all your bases covered and make your life and inspections better and easier.
In addition to what others have said above, I was going to add a good set of channel locks.
Which reminded me of last weeks inspection…
For?
Ten characters
I use them (almost) everyday to remove the cleanout cap. Also occasionally to remove a stubborn hose from the hose bib. YMMV
You carry way, way more than I do. What are the long black things?
Min: Flashlight, moisture meter, 3-prong tester, multi-tip screw driver (include hex), ladders, and a way to present the report (inspection software, MS Word, etc.) PPE for crawlspaces.
Max: Anything you dream of. Thermal imager, sewer scope, radon testing devices, drone, crawlspace crawler, assistant, etc…
