Originally Posted By: David VanderSchaaf This post was automatically imported from our archived forum.
Hi Kirk
I don’t know how it is in the USA, but in Canada, any inspection organisation being municipal, state or federal can not override the engineers specificaltion, these are the ones who design and manyfacture the unit and are responsible for the “safe” operation of the unit. Any person who tries to override the engineers specs imediately takes on full liability for the recommendations the have made.
This may persuade them to comply to the engineers specs.
Originally Posted By: Neil Brinker This post was automatically imported from our archived forum.
Temp, pressure relief valves are a must in case the thermostat fails to open when the water heater gets up to preset temp. Copper or iron is what’s common here and terminated 6’’ above the floor. If this is a basement or garage set-up that makes sense. In a utility closet or living area it would get messy if a drip went unnoticed. In that case there should be a drip pan under heater. Steam increases in volumn 1600 times as it condenses and is at nearly 0 pressure so cpvc would do rated at 180 or 200 degrees. The six inch thing is so you do not get splattered with superheated water directly although your legs would take the hit if you were standing next to it if it happened. Elbows to the outside are of no consequence unless someone plugs the pipe put there. That’s why no threads or cap allowed. There have been electric water heaters launch right through the roof if altered without the tpr valve. Gas water heaters in the garage or utility room must be raised 18’’ off the floor in case there is a gas spill. The “Family Handyman” magazine is an excellent source of information not only for homeowners but inspectors alike. There’s my two cents.
Originally Posted By: Rusty Rothrock This post was automatically imported from our archived forum.
Neil -
Thanks for the excellent explanation of the TRP discharge pipe and the importance thereof. I see so many jackleg plumbers who either don't install one what-so-ever or they might only run it a foot or so down from the top side of the hot water heater. This is obviously a key item to inspect on each and every home inspection.
Thanks for the input. Hopefully all the NACHI HI's out there will read your post.
Originally Posted By: Morgan Audetat This post was automatically imported from our archived forum.
Igor has the right information.
Expansion tanks are for expansion. Normally hot water can expand back into the city water system when heated by the water heater. But with plumbing codes constantly expanding to cover every conceavable scenario, many areas now require a check valve or back flow preventer.
Sorry, an expansion tank can NOT increase pressure in a water system, they are designed to maintain the design pressure - same as at the water meter - throughout the water supply system.
