TPR valve and tankless water heaters
Are TPR valves required for tankless water heaters? I have seen contradictory on this.
Edit: The conflicting information is in Section 5 of InterNACHI’s Residential Plumbing Overview for Inspectors Course. In a written portion it says they are required; in the video it says that they are not because it is not a closed system with a storage tank. It’s pretty arrogant to assume I was getting information from “Facebook, inspector blogs and AI. Hard to believe, eh?” Maybe just try to help someone that is taking the courses instead of being a prick. Thank you to those with actual responses.
What did the Manufacturers Owner/Installation Manual have to say about it?
IMO, if it came with one installed, (as it should), or an installation port for one to be installed, it is required.
They can be hard to see sometimes. I didn’t think this one had one however it was hidden behind the two red-handled valves.
Exactly. Of all of the brands I can think of, they all called for either PR or TPR valve.
Where from? Let’s see.
Facebook, inspector blogs, and AI have been known to mislead people. Hard to believe, eh?
What does manufacturers instructions say and what does your local Code say. I’ve seen electric on demand water heaters where the MI say that are not needed, but they also say install to local Code. Washington State requires them so all should have them. I’ve also seen some MI that say only a Pressure Reducing valve is required.
All the Manufacturers I have seen (in their install guides) require the safety relief valve. However these are Pressure sensing only and not temperature sensing as in a traditional tank type heaters. I have called out a few on new const. which did not have the valves and once a contractor said the city didn’t require it…The answer is: Manufacture requirements overrides codes. So many times contractors will say these stupid things when actually the city guy just didn’t catch it. I’m sure the warrantee is void if the WH is damaged by pressure if not protected with the correct valve.
Martin, don’t know if this is contradictory but this is from ECO Water heater installation guide. Its an electric on demand heater. I’ve run into several of them.
2. This automatic tankless water heater is equipped with both computer-controlled and electromechanical auto resetting thermostat switches for high-limited temperature protection. Since this product does not use a storage tank, the use of a temperature pressure relief valve (T&P) is not required for most installations. UL Standard 499 does NOT require that a pressure relief valve be used. However, a T&P valve may be required to meet installation codes in your area. If one is required, install the pressure relief valve in accordance with local codes and ensure that it operates correctly and that air is purged from the valve prior to installing the water heater. When connecting to Flex or High Temperature CPVC pipe, we recommend that a T&P valve be used for added safety. Please note: Installations in the Commonwealth of Massachusetts and State of Kentucky require a pressure relief valve. Please check your local installation codes for any special requirements.
Our code says they still have to have them though.
