That is 3/4” pipe. Nowhere in the UPC or IPC is internal dimensions mentioned. They only say the discharge pipe should be the same size as relief valve. Until 2018 in the IPC 3/4” PEX met the requirements. After 2018 1” PEX.
You are correct martin
