tpr valve
hey guys
just looking for some info, did a new construction inspection and the water heater is located under a set of stairs on slab in middle of home tprv is terminated into abs drain line, wrote it up as it should terminate to exterior wall , realtor told client that since it was in the middle of home thats how they do it and it is passing local code inspections, I read the code my question is what is a indirect drain ?
Client has called me for a 1 yr warranty just want to cover myself
thanks in advance
keith
http://www.nachi.org/tpr-valves-discharge-piping.htm
http://www.pic.vic.gov.au/resources/documents/6.09_Temperature_-_Pressure_relief_valve_drain_lines.pdf
Thanks for the link to the article. As usual, great info. for home inspectors.
Best Wishes
John M. Wickline
JW Home Inspections, Inc.
www.http://JWInspect.com
JWInspect@hargray.com
Serving the Low Country of South Carolina since 1998, Hilton Head, Bluffton, Sun City, Beaufort, Hardeeville, Ridgeland, Callawassie, and Daufuskie Island since 1998. Providing Home Inspection Services and Absent Owner Services.
