Trane Specs
Originally Posted By: Peter Foxe Smothers
Hi guys,
I am looking for the tonnage and year built of this Trane unit.
Model # 8wv024a100d2
Serial # x14389398
Is the Carrier Blue Book worth the price and the best way to go to find out this info? I know it is encoded in the numbers but I have not learned the decoding process yet.
Thanks in advance!
Foxe Smothers
Originally Posted By: cmccann
Just a guess, but a 2 ton, 1993. Looking at the Preston Guide I’m having some problems finding the MN you gave. My book only covers 1960-2000, is this older or newer then that?
NACHI MAB!
Its an upflow unit in a small apartment. Its probably between 3-8 years old. I double checked the numbers to be sure I copied them right. The unit is in a friends place and I was just trying to see if there was any way to decode the Trane numbers without a guide.
Originally Posted By: Blaine Wiley
Quote:
8wv024a100d2
Being that it is a Trane unit, I think you will find the model number is actually a BWV024A100D2, which is a 2 ton unit.
For the last several years Trane has been putting the manufacture date on the data plate. If it is three to eight years old, it should be there.
Thanks for the help guys.
Foxe Smothers
