CFL Bulbs
March 15, 2007
[http://www.citynews.ca/images/blogs-jee/mar1507-bulb.jpg](javascript:LoadOneClip( ‘8802’ ))
http://www.citynews.ca/style/navigation/OneClip_MockPlayBar.gif
Does this look normal to you? Believe it or not it is.
Sometimes when compact fluorescent light bulbs or CFL bulbs are coming to the end of its life, they shutdown and smoke up. It doesn’t always happen but it can and boy does it stink! That’s what happened to one viewer who contacted me. The light bulb in the picture is hers. While it looks dangerous the Electical Safety Authority say these light bulbs, unless it’s a counterfeit, are safe as long as they’re used properly. The problem is there are poor instructions on packages and in some cases no directions whatsoever.
So here’s a list of don’ts:
- Do NOT use these bulbs in dimmers unless specified.
- Do NOT use these bulbs in recessed lights and track lighting unless specified.
- Do NOT use these bulbs in areas where it goes hot and cold, i.e. cathedral ceilings or outside, unless specified.
- Do NOT use these bulbs in a bathroom where there is a lot of moisture unless specified
There are specific CFL bulbs that you can use in the areas mentioned above. They are more expensive but there should be no price tag on safety. Just make sure you read the instructions or look for pictures on the package. If there are none, contact the manufacturer for proper use.
While some bulbs will burn this way, is it acceptable? Electrical Safety Authority (ESA) says NO!
ESA is working with manufacturers to improve packaging instructions and improve the way these bulbs end their life. They are hoping these changes will be in effect next year. In the meantime, check out my one-on-one interview with Ted Olechna. He is the provincial code engineer with ESA. You can also check out the full story on citynews.ca
