Truss web removed
(Scott Smith, 16000082097) #1
I inspected an attic with 4 truss webs removed,I called it out on my report but the excuse I got from the realtor was that the hvac guy removed it so it must have been approved.Im sure it wasn’t, just by the way it was braced up.i recommended a structural engineer,should I recommend obtaining the paperwork stating approval of the work or not.
(Roy D. Cooke, Sr) #2
No you have done your job just be sure it is well written in your report .
Its called CYA cover your *****. Roy C
(Dave Fetty, CMI) #3
Trusses can not be altered in any way unless approved by an engineer. Engineer documents have the engineer’s stamp and signature. Some realtors crack me up!
(Kevin M. Leonard, CMI) #4
What they said.
This entire article is an excellent read, but in this instance scroll down to “alterations” and send it to your client and the Realtor.
(Larry Kage, CMI) #5
Oh yeah, that’s okay…:roll:
(Marc A. Goldenberg, Inspector Lic # HI1365 Mold Assessor Lic #1) #6
This is what I use in Florida:
*The Trusses have been damaged as seen in the attic,
this is a violation of the Florida Building Code for Existing Buildings as Trusses/Rafters are not to be “cut, notched, drilled,
spliced or otherwise altered in any way” unless approved by a RDP
(Registered Design Professional Engineer).
Additional evaluation in a more technically exhaustive fashion is required by an RDP per the Florida Building Code, this should take place before occupancy of the structure.
(William B. Ogletree, TREC License #22530) #7
(Jeffrey R. Jonas) #8
But Larry… I’m sure her “regular” inspector told her it’s a-ok!! :roll:
(Larry Kage, CMI) #9
JJ, as Bruce so eloquently put it: ](*,)
