I have some basement walls that need attention. Anyone have any good resources on tuct pointing?
Hi. Jeff;
Hope this helps.
http://www.brickinfo.org/pdfs/Repointing%20Brick%20Masonry.pdf
http://www.cr.nps.gov/hps/TPS/briefs/brief02.htm
http://www.maconline.org/tech/maintenance/point1/point1.html
http://www.wes.army.mil/REMR/pdf/cs/mr-9-5.pdf
Marcel
I have watched Brickies do it and it is easy .
I tried and it was a disaster.
I had to do my chimney.
What I found is Home Depot has a big BAG look like the Bag chefs use for writing on a cake .
It is made for just what you want to do .
So you have two choices the way I see it Give Marcel a paid holiday or go to Home Depot and do it your self.
I did it in the hot weather so lots of water on the Bricks and try and do the shady side .
It turned out great Cost under $10;00.
Good Luck /
Roy Cooke
Marcel
That’s very good info!!! Thanks
Great info Marcel. I unfortunately can’t give you any reputation, though. I recently gave it to you on another post. I need to be less stingy with my squares.
Roy, same story.
You got it Roy, that is exactly what they are. So if you are a good cook, it’s a piece of cake, with decorative frosting decor. ha. ha…
Marcel
P.S. You are welcome Mario.
Jeff
I got it covered, I just gave Marcel and Roy rep.
