Client wants to install plasma TV on wall above (gas) fireplace mantel. Is this OK?
Thanks
Thanks
Yes, provided it is high enough.
Does this fireplace have a fan unit installed? Is there a mantel above the fireplace? Is there is an alcove above the fireplace where they can recess the TV? I would be very wary of installing an expensive piece of electronics above a fireplace with a fan unit due to the heat it puts out over and above a normal gas unit. I think it would shorten the lifespan of the TV with the increased heat. IMHO.
A dealer of flat-screen TV’s told a client of mine that installation above a fireplace was not recommended by the manufacturer. Sorry, I don’t know names or brands.
Erol,
You may want to pass this info on to the client.
http://www.plasmatvbuyingguide.com/plasmatvreviews/plasmatv-fireplace.html
Thanks guys. Barry, you remind me of the ‘Shell answer man’ if you’re old enough to remember him.
Erol,
Just try to help when I can and the net makes my job easy
Don Morrow was his name
Here I am in another life :shock:
