belliott
(Bob Elliott, 450.0002662)
May 30, 2009, 2:52am
#1
I am wondering if there is anything wrong with two water heaters touching ,though I am recommending drain pans as a side note.?
Seems that though there is a floor drain in front of them the floor slants towards the bedroom door in back of them.
P.S …1st floor slab
Only if they are married…
jpope
(Jeffrey Pope, CMI)
May 30, 2009, 3:22am
#3
Generally, it’s not a problem. The clearance requirements are listed right on the units. Usually it’s 0" sides and back.
belliott
May 30, 2009, 3:31am
#4
Thanks
Guess the only problem is finding room for the drain pans.
Flip special bought in January with the seller / flipper there.
Old 2 flat
bkelly2
(Brian Kelly, AZ Cert. # 60234)
May 30, 2009, 8:03am
#5
They look same sex to me Jae…
wcorbett
(William M. Corbett)
May 30, 2009, 12:49pm
#6
I would not normally think any thing of it either However for the sake of this discussion, with the combustion draw at the bottom of the water heaters, I wonder if that may cause some issues.
belliott
May 30, 2009, 1:46pm
#8
Actually they still need to add the room air requirement
The cat 4 unit is to the left (note panels are out)
There are water heaters in California…
