UK membership of interNACHI
Is there any benefit for someone from the UK joining interNACHI?
From what I can see the building regulations are all different and I don’t think this is recognised in the UK. The only thing I found of use was the Infrared course which I have now completed and passed.
Look forward to your replies.
What do you expect to gain from ANY Organization? Knowledge about Regulations? Building Construction? General knowledge of the Industry?
I would expect most everything is different country to country, but there should be general knowledge that applies to the Industry overall, and unless you have a reputable source for information to rely on, what are your options? In America, all of our 50 States have local and regional differences, but are common enough in nature that make it worthwhile to learn all one can from any of the areas.
Remember. knowledge is power, and the more you have, the stronger you will become in this industry.
The IRC is the International Residential Code, emphasis on International. Home inspectors are not code inspectors but obviously, most of what we inspect is governed by code requirements. Good and best practices are universal. Differences exist between communities here and possibly in the UK (will northern Scotland have the same heating and insulation expectations and requirements as southern England?). Structural, plumbing, electrical, and heating/cooling have basic universal best practices. Studies and interactions with InterNACHI and our fellow home inspectors helps all of to be better at what we do. And maybe, if enough UK inspectors join up, there will be a UK forum for you guys and gals to share information.
Keep in mind that we are not code (regulations) inspectors. We are home inspectors, and that means everything from proper grade for site drainage to a proper roof installation. I would think that general knowlege of different systems and how they function would be universal, and even though, for example, the UK electrical standard voltage is 240 vs 120 for the US, the principles of electricity are the same.
Same goes for HVAC or boiler systems, Plumbing systems, etc.
IMO the education value that InterNACHI offers is a huge asset that in and of itself alone is worth it to me to be a member.
In the end though, it’s up to you to decide if you find value for you in being a member or not.
