Explain this image if you even think you understand IR
I was playing with a heat pump Monday and shot this image for fun and got to looking a little closer in the office.
The HP was in operation at the time the image was taken the exterior ambient was about 50 degrees F Notice the compressor temp above 200 degrees the surface temp of the dischage line out of the compressor drops to about 65 F and then the inline dryer temp is 201 F. The discharge line between the compressor and the dryer is roughly 6 inches in length. Explain the temp differential between the compressor and the dryer;-)
