ccurrins
(Christopher Currins, CMI)
July 27, 2014, 6:57pm
#1
Is it acceptable to replace a 2-prong (2-wire system) receptacle with a non-grounded GFCI for a washing machine?
Or does a grounding conductor need to be installed?
This is at a remodel with new service panel/original 2-wire system; the receptacle presently installed for WM is 2-prong.
sstanczyk
(Stephen Stanczyk, WA License #221)
July 27, 2014, 7:08pm
#2
The appliance will likely require a grounding conductor but most with this type of installation run a separate wire from the frame of the appliance to the metal water pipes.
ccurrins
July 27, 2014, 8:39pm
#3
Thanks Steve. I didn’t feel a GFCI would be adequate.
jjonas
(Jeffrey Jonas)
July 27, 2014, 9:18pm
#4
Surprised Illinois didn’t require the appliance grounds when the panel was updated. Perhaps a call to the AHJ is in order.
ccurrins
July 27, 2014, 10:46pm
#6
I think we have the same opinion regarding GFCI protection and equipment ground protection.
I found this thread earlier. Cameron posted a Whirlpool Washer Installation Instruction at post #51 .
Stating:
“This washer is equipped with a power supply cord having a 3 prong grounding plug .”
"To minimize possible shock hazard, the cord **must be plugged into a **mating, 3 prong, grounding-type outlet .
Note: The house I inspected had neither (GFCI or grounded rec). Just a 2-prong outlet.
rmeier2
(Robert Meier)
July 27, 2014, 11:22pm
#7
What is the original wiring method?
ccurrins
July 28, 2014, 12:04am
#8
2-wire system, with recently installed/updated service entrance equipment and service panel.
rmeier2
(Robert Meier)
July 28, 2014, 12:38am
#9
So the cable was NM cable without an EGC?
