Originally Posted By: mrose
that we use in our report writing. This can be organized in sections as follows:
Grounds
Garage and Garage Doors
Roof and Gutters
Exterior
Understructure
General Interior
Kitchen and Appliances
Attic
HVAC
ELECTRICAL
PLUMBING
Bathrooms
GENERAL SAFETY
MISSING CONSTRUCTION FEATURES
AREAS NOT INSPECTED
Class Actions/Litigation/Environmental:
Safety Hazards:
Here is an example how to present a listing.
Grounds
It would be beneficial to have a stop/barrier installed at the top end of the driveway to prevent a vehicle from possibly rolling down the grade into the rear yard.
Nails are protruding from the foundation slab. These should be removed to prevent someone from getting cut.
Stored items in the garage limit the visibility and ability to completely inspect this area.
The door between the garage and house is not a fire rated assembly.
Exposed flammable paper insulation backing is in the garage. This paper should be facing the heated area.
A pet door is installed in the door between the garage and house. This is a fire safety issue because the fire rating of the door is compromised. The door should be replaced.
A pet door is installed in the wall between the garage and house. This is a fire safety issue because the fire rating of the wall is compromised. Have this corrected.
The rope attached to the automatic garage door should be removed. This is a child safety concern.
Safety cables are missing from the garage door springs.
The safety reverse is not properly adjusted on the automatic garage door(s).
The manual safety reverse is not properly adjusted on the automatic garage door(s).
The spring in the manual garage door is not properly adjusted and does not hold the door open. It rapidly drops which is a child safety concern.
Do not connect a refrigerator or freezer to the GFCI receptacle in the garage. The receptacle can trip and spoil the contents.
Mike Rose
Cornerstone Home Inspection Co. LLC
Lawrenceville, GA
www.cornerstonehomeinspect.com
