I came across an unusual water heater venting setup in a condo today and wanted to see if anyone else has run into something similar. The heater is located in a tight closet, which limited visibility, but here’s what I observed: instead of a standard draft hood, the top of the water heater was covered with a metal box. The flue connected to that box, and another section appeared to run down the side of the unit.
Has anyone seen this type of configuration before? I’m wondering if this was simply an improvised field modification or if there’s a specific design intent behind it.
Morning, Eric. Hope to fid you well and in good spirits today:-)
Manufacturer, model & serial numbers please.
I have seen this type of gas fired water heater venting before but it was some years ago and I forgot the type of venting off hand.
It Appears to be a Direct Vent - Natural Draft gas fired water heater but PLEASE don’t take my word for it.
Let others chime in.
If my memory serves me well, Marcel Grattan answered this question several times.
Hey Robert, thanks for sharing–I appreciate the feedback. The closet access was pretty tight, so it was tough to get a clear shot of the manufacturer label, but here’s the best image I could capture. From what I can see, it looks like a standard Bradford White atmospheric-vent water heater that should have a draft hood installed directly on top of the tank. That’s why the current setup struck me as unusual. Appreciate you taking the time to weigh in, and I’ll be curious to hear if others have seen a similar modification.
My pleasure. Remember, it does not mean I am right.
I will download the venting instructions from Bradford White. Give me time.
Google: The model number “05140s6bn12” indicates a Bradford White (PV) Power Vent water heater meaning it requires a power-assisted vent system, which can exit horizontally through a wall or vertically through a roof. For correct venting, use the specific installation manual for this model, keep vent lengths to a minimum, and ensure all components and clearances meet the manufacturer’s requirements and local codes.
Common design found in older (80s-90s) Manufactured homes when they don’t want to pay for the ‘through floor’ updraft model! Designed for tight spaces/closets like you have there. Was this closet on the balcony, or next to it for the furnace?
Morning Jeffrey.
Updraft? Is this a new term for gas fired water heater venting?
The reason I ask is I relate updraft venting to kitchen ventilation systems that use atmospheric convection.
Well, technically it is a ‘Direct Vent’ system, but many local (rural Minnesota/Iowa) Plumbers, refer to it as ‘Up-Draft’ regarding the ‘Hole-in-the-floor’ configuration that the combustion air flows through…
