**$1,399.00
Purchases new one year ago. Used once for 2 hours.
Specifications for UV PRO 6800 Ozone generator**
Generation method: UV ozone technology. 12 15" UV tubes driven by hi output preheat ballasts.
UV Tube life: 12-15 months.
Supply Gas: Ambient Air
Ozone output: 6800 mg/hr virtually unaffected by humidity (Unit will produce 7500+ mg/hr for first week).
Control options: - On off rocker switch standard on all models, 3 switches to allow output adjustment in 6 steps. Shock treatment timer with 9 time settings: 2, 4, 6, 8, 12, 18, 24, 36, & 48hr. - PRO 6800 T7D (7 day timer allows for 4 on and 4 off settings every day)
Dimensions/weight: 24"LX 9"W X 6.5"H / 24lb
Electrical: 120 Volt, 5 Amp, 50/60Hz
240 Volt, 5 Amp, 50/60Hz (please note that 240VAC models come with an IEC power cord connector. You will need to supply your own cord, the cord is the same one used on every desktop computer in the world)
Fuse rating: 5 Amp
Fan Size: 105 cfm
Construction: Stainless steel chassis
Special features: The UV PRO 6800 comes equipped with a 2, 4, 6, 8, 12, 18, 24, 36, & 48hr 1 shot timer, optional is a 1 shot timer that will allow operation from 1 second to 24 hours, or a 7 day timer that allows the generator to turn on at different times on different days of the week etc… Due to the 12 tube design and special switching setup of this model, the output can be adjusted in 6 steps by simply turning switches on or off. * Secondary benefit, any air passed thru the ozone generator is “SUPER STERILIZED” by UVC, B, & A. * Also available are non ozone producing UVC tubes for air sterilization. Simply remove all 12 ozone producing tubes and replace with 2 UVC tubes.
Warranty: The UV PRO 6800 is warranted against defects in materials and workmanship for a period of 6 years from date of purchase. The UV tubes are warranted for 6 months. Liability is limited to parts and labor only. Shipping is the sole responsibility of the customer. Crystal Air is not liable for damage caused by shipping, misuse, neglect or lack of regular maintenance.
Uses: The UV PRO 6800 is designed for use as a shock treatment tool.
Ideal for use in garbage compactors, industrial restoration, auto detailing, etc. The UV PRO 6800 will easily reach 3 ppm in a 16,000 cu/ft(2000 sq/ft) space in about 1 hour, or 1.5 ppm in 32,000 cu/ft(4000 sq/ft).
